'89 460 dies suddenly while driving? - Ford Truck Enthusiasts Forums
Old 10-27-2012, 10:25 AM
lvin4jc's Avatar
lvin4jc lvin4jc is offline
lvin4jc is gaining momentum as a positive member of FTE.lvin4jc is gaining momentum as a positive member of FTE.
Exclamation '89 460 dies suddenly while driving?
For the last two months my truck has been trying to die while driving and this morning it finally did. I will be driving along just fine and i'll hear a sound (whisper "shoe" fast and emphasize the "sh") coming from my warped and ticking exhaust manifolds. I'll look down and see the rpm's drop to zero and then come back up again and everything will be fine.
Once it did the same thing only it backfired with a loud pop also.
The only real hint I can give you is that in the 4 times this has happened I was either coasting or on a long downhill with very little throttle. The time it backfired I was on the interstate, I climbed a hill with quite a bit of throttle and then let off completely when I got onto an off ramp.
This morning when it died completely I pulled over and tried restarting once. It didn't fire so I jumped out and popped the hood (once this happened to me in an old suburban and I found a smoking wire that was a big hint so I wanted to be fast). I didn't see anything obvious so I got back in the truck, it started right up and I drove it 5 more miles in to work with no problems.
I definitely get an electrical feeling over a gas problem, what do you think?
If I have to start diagnosing tonight after work I think i'll start with the distributor.
Old 10-27-2012, 08:32 PM
lvin4jc's Avatar
If it helps this happened to me again on the way home tonight.
I was sitting at a light idling, the light turned green so I started through the intersection and the truck died about 3/4 of the way through.
I tried to start it and it just cranked, tried again, cranked, tried again, same thing. So I sat there for 30 seconds, tried it again, cranked and did the same waiting 30 seconds in between 4-5 times, nothing.
I opened the hood, checked the connections at the distributor, pulled the SPOUT connector, plugged it back in (it wasn't loose I was just making sure). I got back in the truck and it started right up.
Since i'm mentioning the SPOUT connector, i'll mention that my truck has the timing issue where I can't advance my timing because when I disconnect the SPOUT the truck won't keep running. I guess most of you can pull it and the truck will keep running while you change the timing. When I pull mine the truck dies instantly. Maybe this is connected, maybe not?
Old 10-28-2012, 02:53 PM
lvin4jc's Avatar
Another hint for you;
The problem has gotten worse but is now very consistent. I've driven four times since yesterday morning. In all four drives, the truck drove about 5 miles and died. It then takes about one minute before it will fire again. Messing with the SPOUT connector does not appear to make a difference and this lat time it happened I was on the throttle climbing an incline so it's not just when i'm coasting.
My guess is that since it has to wait 1 minute before it starts that something must be getting hot that doesn't like to be hot? But once I start it up again it seems to drive fine for a long time, if something was getting hot in 5 miles, I would think once the truck is warm it would get hot again even faster???
Old 10-28-2012, 03:20 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
The symptom you describe is a difficult one to figure out. You need to determine if you are losing fuel pressure or spark. I really suspect the latter. Two common causes of sudden loss of spark is a faulty TFI module or PIP (stator) inside the distributor. The hard part is figuring out which one is the root cause. There are a few troubleshooting procedure you can use.
I like this one the best: Ford Ignition Module Test. Fender Mounted Module (ICM).
This is a good one too: How to Solve an EFI No Start
Invest in a spark tester:
Truck Starts, then dies: Also dies while driving RedDevil460 1999 - 2003 7.3L Power Stroke Diesel 9 08-12-2016 07:07 AM
1989 351 Windsor FI "choke" problems fordbozo 1987 - 1996 F150 & Larger F-Series Trucks 5 05-15-2015 08:38 AM
1985 F150 bullnose 3-2 holley 600 backfires and loss of power Kyre Searcher 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 17 01-29-2015 06:10 PM
HELP...DEAD 6.9 IDI 4 SPD. lambone Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 12 01-10-2015 10:44 PM
460 backfires thru carb after 40 miles XolieX Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 15 10-30-2005 04:56 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
