Reverse noise 7.3 L 2002 DANA 80 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-26-2012, 09:27 PM
c.j.amato c.j.amato is offline
c.j.amato is starting off with a positive reputation.
Question Reverse noise 7.3 L 2002 DANA 80
Today I had a differential pinion seal replaced due to a small leak. When I put the truck in reverse and cut the steering wheel hard I'm hearing a faint grinding sound. Anyone have any ideas? 2002 Ford 7.3 L dually with Dana 80 rear end.
Old 10-27-2012, 08:46 AM
miller_feed's Avatar
miller_feed miller_feed is offline
Hook it, I'll pull it.
miller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputation
Welcome to FTE.
Who changed the seal?
Do you know for sure they put 470 ft/lbs of torque on the pinion nut?
Did you check the fluid level?
Might need friction modifier.
Old 10-27-2012, 02:14 PM
I had a certified mechanic whom I trust do it. I'm starting to suspect a warped rotor.
Old 10-27-2012, 03:42 PM
redford's Avatar
redford redford is online now
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
Sounds to me like maybe they didn't put enough friction modifier into the diff fluid. A warped rotor will cause your brake pedal to pulsate while braking. If you are not experiencing this pulsating, your rotors are true.
Old 10-27-2012, 05:10 PM
My understanding is that friction modifyer is in synthetic 75w-90 severe gear oil. Do you add more and would this do any harm?
Old 10-27-2012, 05:15 PM
kd0axs's Avatar
kd0axs kd0axs is offline
kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.
Are you talking about Amsoil Severe Gear? It says on the bottle that it's compatible with most limited slip diffs, but if you experience chatter to add friction modifier.
I take this to mean that there is friction modifier in it, but some LS diffs may need more.
Old 10-27-2012, 05:25 PM
Yes.... Amsoil 75-90W severe gear is correct. Would it hurt to add a bottle of friction modifer to this? I'm going to purchase a bottle and see if this is the fix. The noise is only at a slow speed, no grinding. Just enough to be concerned when backing up.[/LIST]
Old 10-27-2012, 06:14 PM
Snowseeker's Avatar
Snowseeker Snowseeker is offline
Snowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputation
I used mobil 1 with the modifier in it already. But I seem to recall having to use a heavier 75w 140 or the like, I could be wrong though.
When the modifier is needed the rear end will jerk (chatter) a bit going around corners especially under load.
Old 10-27-2012, 06:44 PM
My "Precious " isn't jumping or anything. I just hear the noise when turning to back out of the drive way. By the way I had to annoy the parts guy at Ford to verify which rear end I had. First they told me a DANA 60 but I insisted they pull it up by the VIN. DANA 60 uses 75-140W, DANA 80 uses 75-90W. My mechanic questioned this also but verified I was correct in my persistence. Ford apologized and just assumed they all use synthetic 75-140W. (That was also initially giving him the numbers stamped on the differential).
Old 10-27-2012, 08:33 PM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
Quote:
Originally Posted by miller_feed View Post
Welcome to FTE.
It takes the torque needed to crush the sleeve and give the proper pinion drag.
Old 10-27-2012, 08:35 PM
Quote:
LS rear end? I wouldn't worry about it.
Old 10-28-2012, 06:05 AM
bucci's Avatar
bucci bucci is offline
bucci is gaining momentum as a positive member of FTE.bucci is gaining momentum as a positive member of FTE.
Quote:
Never heard of putting in a new crush sleeve when just changing a pinion seal. One should always install a new flange nut though.
Rotational torque should be checked before removal of flange nut and then after new seal is installed new flange nut should be torqued to remove play and slowly increased until a specified torque is reached above the initial recorded rotational measurement. Probably around 3-5 in. lbs more than the original recorded measurement.
That's the general procedure, one should always check manufacturer's procedure and to verify spec numbers.
Old 10-28-2012, 11:31 AM
I totally disagree. If you go by torque you can't attain the slight drag it needs. Besides, those specs are for a dry rebuild on a bench. 470 pounds on a sleeve that is already crushed? YIKES!., you wouldn't be able to turn the yoke by hand.
Old 10-28-2012, 02:47 PM
Snowseeker's Avatar
Thats what I am thinking as well. It is the preload on the bearings as well and I don't think I have ever seen any torque numbers over 100ft lbs for any sort of taper bearing. In fact almost all taper bearings require just a snug nut or even allow for a positive tolerance. Over torquing them will burn them up no matter how much oil they are in.
Old 10-28-2012, 03:12 PM
Quote:
The nut torque can't even be used on a seal job. They just need 2 things; a little drag on the pinion and a nut that will stay tight. The old crush sleeve can be used if it applies enough pressure on the nut which is possible due to it's springiness and the wear on the 2 bearings.
2002 lariat once warm no throttle lvanwhy12 1999 - 2003 7.3L Power Stroke Diesel 1 02-12-2015 05:37 PM
2002 Tenvol1968 1999 - 2003 7.3L Power Stroke Diesel 10 11-29-2014 04:53 PM
gears.. Harvester93 1994.5 - 1997 7.3L Power Stroke Diesel 4 11-20-2013 11:55 PM
dana 80 swap? jubbard1 1994.5 - 1997 7.3L Power Stroke Diesel 7 05-19-2010 10:44 PM
stalls in reverse jsphsol6 1994.5 - 1997 7.3L Power Stroke Diesel 5 11-13-2006 04:16 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
