You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
NumberDummy may be able to help, but that is likely a tag from the company that modified the truck.
Orville Ohio , where your truck was modified,is about 20 minutes from Where I grew up(?).Though only about half the size of my town,they regularly kicked our azzes in high school football, often advancing far in the state playoffs, winning it occasionally.
Can you post the VIN tag from inside the glovebox door?
__________________
"Why, yes, I have plenty of spare change, you worthless piece of crap."
'59 F250 w/an Engine, a Transmission, Some Tires/Wheels, PLUS-a Genuine Radio
removed the front clip tonight on the crew cab,found a build tag
27-66 S 704696
F1 3-1 110
HTR1 LH DOOR LOK
GOVT JOB CHANNEL BUMP
Also found tag on rear seat frame: Orrville Metal Specialty Co
model serial 110-140
I forgot to write the serial # down
I assume the 110-140 means a reg short bed wheelbase is 110, this trucks wheelbase is 140
Any info on the build tag?
This is not a build tag per se, it's a "buck tag" used by assembly line workers to make sure the installed parts match the vehicle order.
Truck was ordered by a US Gov't agency with a heater (optional), left front door lock cylinder (optional on Standard Cabs), rear channel bumper (all rear bumpers were optional thru at least 1979).
The "buck tag" on the seat is related to the seat maker only. Again, it was used by assembly line workers to make sure the seat matched the vehicle order.
All seats have "buck tags" because all were bought from outside suppliers. If y'all think that FoMoCo makes all the parts on their vehicles, think again. No more than 10% of the parts are made by FoMoCo.
That's why they're called assembly plants, because vehicles are assembled using a gazillion parts shipped in by 100's of different suppliers.
All these Crew Cabs were outside conversions. FoMoCo didn't offer a factory Crew Cab until mid-year 1965, and it too was a conversion from a Regular Cab, as were 1966/72 Crew Cabs.
Look in any Ford truck parts catalog prior to 1973, see if you can find ONE specific Crew Cab part. Lotsa luck, cuz there's nary a one.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
The seat tag is the coach house that that built the cab, Orville Metal Specialties. Many crews from that era have that tag and I don't think you'll find it on a reg cab.
