86 Ranger 2.3 EFI NEED HELP with Ignition Starter Switch Install
Old 10-26-2012, 07:44 PM
bozo4ford's Avatar
bozo4ford
bozo4ford is offline
Unhappy 86 Ranger 2.3 EFI NEED HELP with Ignition Starter Switch Install
1986 Ranger 2.3L EFI Gas
5-Speed / 4 Cylinder / SOHC / 140 CID
Standard cab / 2 Wheel.
Instead of reading all my previous posts, on possible reasons why I'm having starting problems, I thought this would be "TO THE POINT", on my most recent problem.
I removed my steering column shroud and noticed the IGNITION STARTER SWITCH harness, or actually the white piece that usually is attached to the grey FORD metal bar, with the two (security) screws, had been broken and separated.
I went to PEP BOYS and got a new one for $10.00. This SWITCH came with a wire that wraps around from this grey bar to the other side of the white MALE pin side.
I asked this guy what I do with the thin wire, and he told me first, to line up the column PIN to the Hole of the NEW SWITCH, plug the harness in, then remove the wire.
I tried starting it up, but all I got was the buzzer, brake, and seatbelt lights, but the lock cylinder continued all the way forward to start, but nothing!
Then I thought maybe I would have to unlock the key cylinder and position the pin into the hole. I moved the key to on, I saw the spring inside of the starter switch move, but it does not start at all.
What am I doing wrong? Shouldn't I just have to align the pin from the column into the NEW SWITCH HOLE, re-tightened the 2 screws, and it should start right up?
I found a Starter switch online to give you an idea what they look like. Click on this.....
More Information for STANDARD MOTOR PRODUCTS US98
Old 10-27-2012, 03:43 PM
bozo4ford's Avatar
bozo4ford
OK, well I figured it out. (OCT. 27, 2012)
I thought the accentuater pin from the column fits right into the small hole on topside of switch with the Key in the "Lock", or OFF position.
What I did, was turned the key just after the START, and to CAREFULLY slide the white top of starter switch to where the accentuater pin is stationed, then push up and re-screw the two screws, hooked up the Neg. battery cable, and VOILA! it started right up, and even sounds better than before with a good strong idle.
If anyone is familiar with my previous postings on my troubles trying to figure out if I'm having Fuel or electric problems, I hope this Started switch replacement will have done the trick.
In assessing my troubleshooting, and without running any codes, I ended up having to replace a bad TFI MODULE, and a bad STARTER. I thought my EEC-IV PCM was to blame, but that either works or does not, but now it works with the original PCM. I'm returning the one I bought, just to have on hand, in case
I also replaced Spark plugs, Plug wires, Cap and rotor,, Fuel Filter, Fuel relay, and ECC relay (both located on fender, pass. side, engine. I also replaced my Fuel pressure regulator, and so far, so good.
For my 1986 Ranger 2.3L
*PCM EEC-IV Computer bought at AutoZone Cardone ( # 78-4323) $130.00 + Core
*IGNITION STARTER SWITCH bought at Pep Boys ( BWD # CS96) $10.00
Thanks!
William McCoy
02-04-2012 04:06 PM
therifleman556
07-11-2010 09:03 PM
kona72
08-31-2007 09:26 PM
charlie2dogs
Electrical Systems/Wiring
01-07-2007 09:16 PM
Vern Anderson
09-12-2004 03:19 PM
Quick Reply: 86 Ranger 2.3 EFI NEED HELP with Ignition Starter Switch Install
