Transmission - Ford Truck Enthusiasts Forums
Transmission
Old 10-26-2012, 05:06 PM
Michael Manifold Michael Manifold is offline
Michael Manifold is starting off with a positive reputation.
Exclamation Transmission
I have an 05 F350 Dually with the 6.0 in it and 94,000 miles. My truck got towed and when I went to pick it up I only have reverse. I put it in drive, 1, 2, or 3 and after a minute I have REVERSE not drive. Tranny goes into reverse just fine when I put the shifter in the reverse position. Fluid looks good not burnt or old. Tried resetting computers by disconnecting the batteries and that didn't work. Any ideas on what might have happened when they towed my truck?
Thanks
Old 10-26-2012, 05:45 PM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
Did they tow it by the front end or rear end? Have you had the truck code scanned?
Old 10-26-2012, 06:55 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is online now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
If they towed it longer and faster than is allowed with the rear wheels on the ground the trans is now junk and needs to be rebuilt.
There is a one way clutch in the trnas that has no sense of humor about running without lube. Towing with the engine off runs this one way clutch without lube, destroying it.
Old 10-26-2012, 07:26 PM
khadma's Avatar
khadma khadma is offline
Carpenter Local 745
khadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud of
I NEEDED TO TOW MY BRONCO TO AN EXHAUST SHOP TO COMPLETE AN
ENGINE SWAP. I MADE SURE I WAS AROUND TO SEE THEM HOOK UP
FROM THE REAR OF THE BRONCO.
FLAT TOWING/TOWING WITH REAR ON THE GROUND IS A GOOD WAY TO KILL AN AUTOMATIC TRANSMISSION.
SORRY WE DONʻT HAVE ANY GOOD NEWS FOR YOU.
Old 10-26-2012, 09:11 PM
Fulthrotl Fulthrotl is offline
Fulthrotl has a great reputation on FTE.Fulthrotl has a great reputation on FTE.Fulthrotl has a great reputation on FTE.Fulthrotl has a great reputation on FTE.
eww. sprague clutch? i learned everything i know about them
at the hands of a 390 Husquvarna automatic, circa 1978.
there are a number of things they don't like.
imagine a caged needle bearing, but instead of needles, there
are these little dogbone shaped segments that slip one way,
and jam against each other the other way, preventing the shaft
and housing from turning relative to each other.
the dogbone shape on the bottom has a small edge overhanging.
without lube, that litte overhang splinters off, and then the
dogbones don't jam together and lock.
DON'T RUN THE ENGINE... all you are doing is circulating those
little scraps of metal thru the trans and cooler, if they aren't already.
mark would know more than i about this... all i know is that the
husky would eat them at very bad times... like halfway between
pasadena and lake isabella on a two day enduro...
Old 10-26-2012, 11:29 PM
Alex332's Avatar
Alex332 Alex332 is offline
Alex332 is starting off with a positive reputation.
Looks like the tow shop is going to be buying you a new tranny!!! Make sure you get a new cooler too
Old 10-27-2012, 12:20 AM
Yahiko's Avatar
Yahiko Yahiko is offline
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
Mark Kovalsky,
Please remind us what the limits are for ground towing.
Thank You for all your help.
Sean
Old 10-27-2012, 01:44 AM
strokin83's Avatar
strokin83 strokin83 is offline
strokin83 has a good reputation on FTE.strokin83 has a good reputation on FTE.
Not good. Hope the tow company owns it.
Old 10-27-2012, 02:26 AM
Yahiko's Avatar
They should know that they can't tow it that
way. You may have to take then to small claims court.
Sean
Old 10-27-2012, 06:08 AM
Quote:
Originally Posted by Yahiko View Post
Mark Kovalsky,
Sean
I don't remember, the limits are different for different transmissions. That's why I referred to the owner's manual, it's in there.
Old 10-27-2012, 08:06 AM
I wasn't there when they picked the truck up, but I think the guy said he popped the tranny linkage and put it in neutral from under the truck. Don't know if he towed it from the front or the back, all I know is truck was fine and now I have a truck that only wants to go in reverse even when I put it in drive, checked the linkage and the linkage is back on right. Come to find out my front hubs were locked in as well, but unless the transfer case was engaged I don't think this would have any affect on it.
Thanks for any feedback
2000 F350 sputtering in reverse Happy Beggar 1999 to 2016 Super Duty 0 10-12-2014 03:39 AM
Reverse Lights cray0971 1973 - 1979 F-100 & Larger F-Series Trucks 14 08-25-2011 09:46 AM
stalls when put in reverse ! ludie 1999 - 2003 7.3L Power Stroke Diesel 2 01-28-2010 05:54 PM
Tranny problems i eat hybrids Excursion - King of SUVs 10 01-02-2008 09:41 AM
delay when putting into gear yellow72f100 1967 - 1972 F-100 & Larger F-Series Trucks 4 06-03-2006 09:52 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
