Engine swap V8 or V10? What to do?
Old 10-26-2012, 12:08 PM
XbigXredX's Avatar
XbigXredX
XbigXredX is offline
Hi all,
I have a 2000 Excursion with a V10 currently in it. The motor is toast and it needs to be replaced (spun bearing). Been having some issues finding a used V10 and my mechanic wants to put a V8 in it. He says the V8 is easier to find and will save us money in the install and rebuild.
1- Will the V8 get better gas mileage?
2- Will putting a V8 in reduce resale value?
3- Any other thoughts on this swap?
Thanks for looking and thanks for any help!
Old 10-26-2012, 12:26 PM
king-david's Avatar
king-david
king-david is offline
Originally Posted by XbigXredX
Hi all,
Depending on if you're towing or not... you wont see much of a gain either way.
Yes
No idea on difficulty, or where you live... I've seen V10 drivetrains on craigslist for 800$
If it's not your everyday driver.. pull the engine... have it rebuilt!
Old 10-26-2012, 12:30 PM
neilc88's Avatar
neilc88
neilc88 is offline
Eco-boost the Ex. That is the way to go if you have to replace it.
Old 10-26-2012, 12:47 PM
1 Excursion camper's Avatar
1 Excursion camper
1 Excursion camper is offline
How about finding a Supercharged 5.4L lightning motor?
Otherwise just have the crank turned on the V-10 and install new crank and rod bearings! then new chains!
Old 10-26-2012, 02:26 PM
cay5628's Avatar
cay5628
cay5628 is offline
Being the (proud) owner of a V10 Excursion I'm a little biased.... my vote would be fix your existing V10. I think you'd be happier in the long run. It's doubtful you'd see better mileage from a V8, but I don't know how you drive or what you use the Excursion for.
-Mark
Old 10-26-2012, 07:48 PM
1 Excursion camper
I really do think rebuilding the V-10 is the way to go. I would also suggest a new oil pump while your in there and maybe even new cams I think someone make HP cams for the V-10, but I`m not sure. now would also be the time to swap out the EXH. manifold bolts and maybe a set of new headers!
Old 10-26-2012, 08:04 PM
Tom's Avatar
Tom
Tom is online now
Possibly, but it would be a minimal increase if any.
Yup. Guys like me wouldn't even consider buying it. 5.4L Excursions are rare, and most don't really want one.
Yup. How'd this one break? How many miles?
Old 10-26-2012, 08:14 PM
Kdr358's Avatar
Kdr358
Kdr358 is offline
After all the time and hassle it wont be worth it. You will need to change the PCM, and all the wiring meaning the entire harness. The transmissions should interchange with the PCM but I am not 100% on that. Re-build the V10!
Shop around, the V10 isnt hard to re-build, its a 5.4 with 2 cylinders added.
Old 10-26-2012, 08:32 PM
EXv10's Avatar
EXv10
EXv10 is offline
You coulda had a V-8!...............but I wouldn't want one, not here anyway.
Old 10-26-2012, 09:49 PM
1 Excursion camper
OOH OOH OOH!!! If you want to do a motor swap how about a CUMMINS conversion?
Old 10-26-2012, 10:51 PM
XbigXredX's Avatar
XbigXredX
Ok, so for all the replies, here are some answers-
This is a second X for the family, my main X is still a V10 running well (crossed fingers).
This one likely would just get fixed and sold.
I looked up the values on a V8 and V10 on KBB and it doesn't seem as if the value is hurt substantially. Seems the difference between values on equal trucks is roughly $300-$500 overall.
I happen to believe that the V8 over the V10 may actually be a selling point in the current market. Even though the V8 may not save a substantial amount of gas over the V10 many people believe it does just because a V8 is smaller than a V10. And as everyone is so gas conscious at the moment it might actually help.
@neilc88 I wish I could find an eco boost motor, but it is really unlikely.
@1 excursion camper A lightning motor would be pretty damned awesome, but again really unlikely tbh
@crazy001 was winter, snow on the ground, coming uphill, minding my business, tires started to spin, leaned on her a bit, tach hit 3500 and the engine banged and that was all she wrote, spun a bearing. 156k on her.
@kdr358 Have a Triton 5.4 complete with all wiring harness and pcm all ready to go, half the price of the v10 if I could find one. Which for 6 months I haven't been able to do. Not for any reasonable prices anyway.
@1 excursion camper I would do a diesel swap in a hot second if I could find a truck to do it with. I don't even care about the hassle involved I would still do it. But I'd need almost everything and that is all but impossible to find anywhere, so I am sool.
Old 10-26-2012, 10:57 PM
BroncoRN's Avatar
BroncoRN
BroncoRN is offline
Its not the price of the v8 vs v10 its the marketability. Most people looking for a this truck have done some research...
Old 10-26-2012, 11:07 PM
king-david's Avatar
king-david
And in my years, one thing I've learned... KBB means absolutely nothing if you have a vehicle someone wants, or doesn't want.
Old 10-26-2012, 11:51 PM
Kdr358's Avatar
Kdr358
Kdr358 is offline
If you plan on selling it have you looked around for a used V10? Most people looking at these trucks really dont really mind that its a V10. Everyone knows the 5.4 is rather under-powered for a truck just under 9,000lbs. Add that plus gas, family, luggage possibly a TT it might be a little tough on the motor. I think that explaining why the motor was swapped will raise other questions. I vote Keep the V10, A set of bearings and polish the crank and you should be good for around 1,000.00.
Old 10-27-2012, 12:18 AM
EXv10's Avatar
EXv10
EXv10 is offline
That sounds like you are trying to convince yourself of something. If one person agreed with you you would be sold on it but most would dis-agree with it. Most people want something that gets out of it's own way.
Quick Reply: Engine swap V8 or V10? What to do?
