Starter Removal - 2000 F-250 Super Duty V10 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-25-2012, 05:28 PM
missin44 missin44 is offline
missin44 is starting off with a positive reputation.
Question Starter Removal - 2000 F-250 Super Duty V10
I'm new to the board and hope someone can help me out. Are there 3 bolts or 2 holding starter in? I'm guessing there is one hidden on top. if any tips to get it out and more importantly to get it back in?
Thanks
Old 10-25-2012, 07:13 PM
DarrellinCeres DarrellinCeres is offline
DarrellinCeres is gaining momentum as a positive member of FTE.
Yes there are three of them. Use an extention (about 6") to get forward of the starter. It's not straight across from the bottom one. If you run your finger along the housing flange from the second lobe up you'll feel the edge of the third lobe.
Goes back in the same way with an extension. There is a flange or something on the block that keeps you from feeling it. I just pulled mine when I did my transmission.
Old 10-25-2012, 08:41 PM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
To avoid rounding the bolt head of that top bolt (especially!), use a 3/8" 6-pt IMPACT Socket. Use anything else and round it off, I told you so.
Less than 10 bucks at Harbor Freight for a set.
Old 10-25-2012, 08:43 PM
BigPigDaddy's Avatar
BigPigDaddy BigPigDaddy is offline
BigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to behold
Quote:
Old 10-26-2012, 09:28 AM
I don't know about it needing to be an Impact socket. I have Snap-On 6pt sockets and haven't stripped the head on one that wasn't already damaged beyond removal.
I guess that if you are using Harbor Freight sockets the impact ones would be better.
Of course that doesn't count on driveline bolts. Who the hell came up with a 12pt bolt head? dam engineers.
You know when I first responded to this post i had a feeling of dejavu
Old 10-26-2012, 10:39 AM
DetailerDave's Avatar
DetailerDave DetailerDave is offline
DetailerDave is starting off with a positive reputation.
I used a 24" extension with a flex socket (6 point) and it worked like a charm.
Old 10-26-2012, 08:49 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
Also take the inner fender out and the wheel off obviously, 10X easier when you can sit there and look right at it. Top will still be behind the exhaust manifold but you aren't trying to reach up and over the starter from your back.
Old 10-26-2012, 09:30 PM
Got it thanks for the help.
Starter still grinding occasionally DrZoom 1987 - 1996 F150 & Larger F-Series Trucks 16 04-06-2016 12:42 PM
Header/starter clearance? tartar_sammich 1961 - 1966 F-100 & Larger F-Series Trucks 29 05-31-2015 05:17 PM
Best Starter Out There, Survey Automator 1999 - 2003 7.3L Power Stroke Diesel 17 08-15-2013 03:42 PM
F-350 Inline 6 Starter Appetite Flughafen Leiter 1973 - 1979 F-100 & Larger F-Series Trucks 2 07-27-2012 07:19 PM
Transmission sensor and starter relay NavyMIDN08 1999 to 2016 Super Duty 1 09-10-2011 10:10 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
