1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Swap 5.4l with v10
Old 10-23-2012, 09:12 PM
Cajundawgs's Avatar
Cajundawgs
Cajundawgs is offline
Swap 5.4l with v10
I have A 1999 f-250 that has a 5.4l with a 4R100/E40D.. My friend wreck his dads truck and will let me have the motor which is a v10 in a 2001 f-350.. Would the v10 bolt to my trans? I know I have to wire it and stuff but will it bolt up? Thanks!
Old 10-23-2012, 09:48 PM
Tom's Avatar
Tom
Tom is offline
It will bolt up just fine, but you'll need the PCM, main harness, and some other stuff from the donor truck to make it all work.
Old 10-23-2012, 11:06 PM
Pickupmanx2's Avatar
Pickupmanx2
Pickupmanx2 is offline
Really, really?!?! (said in Shrek's voice!) This I did not know,, gonna file that away in the BHG for later use!!
Old 10-24-2012, 08:58 AM
phillips91's Avatar
phillips91
phillips91 is offline
The v10 and 5.4 are the same engine, just two extra cylinders, so like Tom said everything will bolt right up. If he wants to get rid of the entire truck I would look at getting it too just in case you need some extra parts for the swap.
Old 10-24-2012, 09:38 AM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
the radiator will be bigger in V10 truck so id swap that too, plus the motor mounts etc. Id just take the whole truck and take everything that goes with the V10 truck
Old 10-26-2012, 01:52 PM
Cajundawgs's Avatar
Cajundawgs
I found that I have 2 rockers/lifters that wasn't in place so I belive this is the reason I have a dead cyclinder and the rest have 130 psi..I got the whole truck with the v10 to use all the parts but hope I don't have to use it..
Old 10-26-2012, 07:17 PM
phillips91's Avatar
phillips91
Is the truck with the v10 fixable or is it totaled? Are you still planning on doing the engine swap now that you know what is wrong with your 5.4? Keep us updated and be sure to post pics if you do the swap
Scottt Bealss
05-24-2017 03:27 PM
67highboy
20
12-11-2015 11:46 PM
m350
Modular V8 (4.6L, 5.4L)
11-10-2015 06:05 AM
20015.4f350
07-01-2013 10:26 AM
brad boyington
Modular V10 (6.8l)
11-03-2011 05:44 AM
Quick Reply: Swap 5.4l with v10
