2008 F350 front hubs won't auto engage 4x4 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-25-2012, 01:29 PM
xpl0sive xpl0sive is offline
xpl0sive is starting off with a positive reputation.
Hey guys, I'm having an issue with my front hubs in my 2008 F350 6.4 Diesel Harley... To engage 4x4 inside, it's just the **** that i turn, not a floor shifter.
The transfer case engages, but the hubs won't lock. I have to get out of the truck, take off the wheel caps and manually turn the hubs to "Lock", if I keep them on "Auto" nothing happens, only RWD works...
I think I read somewhere that these "Auto" hubs are vacuum actuated. Could the hubs be the issue and not holding vacuum? Or is there some vacuum pump that could be broken? The truck has 70k miles on it, so it's out of the powertrain warranty where would I start diagnosing this problem?
Old 10-25-2012, 01:48 PM
Also, do you have to be rolling to engage 4x4? I only tried engaging it when I was already stuck in the sand. I read in one of the threads that the hubs will only lock while rolling?
Old 10-25-2012, 03:20 PM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
No, you do not have to be rolling to engage 4H.
Until you can fix them, just lock your hubs manually when you need 4x4.
The hubs do not "hold" a vacuum, it is more like a vacuum pulse engages them.
Do a forum search on ESOF, you will find a ton of information on what to check and fix.
Old 10-25-2012, 03:29 PM
ryanf250 ryanf250 is offline
ryanf250 is starting off with a positive reputation.
from what I was told there is a seal in each hub that will need replaced to fix the switch activating 4x4, a wide rubber seal in the hub, $45 part, I have the same prob. I asked in thread of the time and dificulty in repairing this, but you are on the right track.
Old 10-25-2012, 03:34 PM
redford's Avatar
Quote:
That may or may not be true. The issue could also be a torn or unplugged vacuum line, a vacuum leak, a weak vacuum pump, a bad vacuum solenoid or a bad (slagged) hub. Each will require being looked at to determine the point of failure.
Blindly telling someone it is a "seal in the hub" isn't helping and may be hurting the issue.
As I stated earlier, do a forum search on the term "ESOF" and start studying.
Old 10-25-2012, 04:09 PM
sorry, just what mechanics told me about this, they say the seals are usually shot after 100k miles...most common, and a possibility, should have said that. do let us know th outcome...
Old 10-25-2012, 04:45 PM
maverick22's Avatar
maverick22 maverick22 is offline
maverick22 has a good reputation on FTE.maverick22 has a good reputation on FTE.maverick22 has a good reputation on FTE.
Quote:
I always heard the wheel needed to rotate just slightly, like 1/2 turn to fully engage, that if you were already stuck it was too late (to auto lock). To the OP, have you tried the ESOF since you got out?
If it still doesn't work, you likely have a vacuum leak, you'll just have to start tracing lines. A vacuum gauge would be a big help as well.
Could also be the o-ring on the hub, and that's probably a $4-5 part. If just throwing money at it, I'd check that first. I'm no expert on ESOF but not even sure what seal that would be.
Old 10-25-2012, 08:42 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
truck does not need to move to engage the front on the later models.
If you hvac defaults to defrost then it is a sure sign of a vacumn leak.
Old 10-25-2012, 08:46 PM
i just got the truck back from the dealership after some maintenance work. tried the 4x4 while driving. i felt it engage. The steering wheel got tighter and felt like the wheels were binding when turning so I think the hubs may have locked. not sure though. I did head the vacuum pump turn on when I engaged 4x4, then i heard it again after I disengaged it. does that sound right?
Old 10-25-2012, 08:51 PM
senix's Avatar
Quote:
yes...just verify if the hubs are in auto or locked as well.
Also it is a good idea about once a month the manually lock the hubs and drive a little.
Keeps it all working right.
Old 10-25-2012, 08:54 PM
they are in auto... the dealer did replace some vacuum lines in the engine bay they said. so that may have fixed my issue
Old 10-26-2012, 09:59 AM
ddbck's Avatar
ddbck ddbck is offline
ddbck is gaining momentum as a positive member of FTE.
If in "auto" tires need to be slightly moving but not spinning out, to engage. if done manually you can be sitting still. Thats what my owners manuall says. I even verified it in the snow. some times it even takes 10-15 ft to engage in the snow when hubs are in auto.
Old 10-26-2012, 10:43 PM
c.j.amato c.j.amato is offline
c.j.amato is starting off with a positive reputation.
Keep a eye open for the vacuum hose on each side. They generally start to dry rot after a couple of years. I change mine out every 3 years. Cost maybe $3 for hose. I haven't had your problem reoccur again. Also, watch for any diesel leaks. Diesel will flare these hoses up.
locking hubs Bigred16 1999 to 2016 Super Duty 3 04-28-2016 11:51 PM
2003 F250 4x4 ESOF sometimes engages, sometimes wont engage chris2888 1999 to 2016 Super Duty 5 01-25-2016 10:15 AM
2009 F250 Powerstroke 4x4 auto won't engage. Troy_455 1999 to 2016 Super Duty 9 07-13-2015 09:37 AM
? on auto/locking hubs jjlrrw 1999 to 2016 Super Duty 8 11-13-2014 10:10 AM
4x4 won't engage without hubs locked davbeisner 6.0L Power Stroke Diesel 2 10-04-2013 03:03 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
