92 Explorer Radio Harness
My wiring harness has been clipped, it is a "shielded cable" and has 8 wires.
Wire Colors:
Brown
White/Red
Yellow
White/Orange
Green
Purple/White
Light Blue
Light Blue/Black
Metal Wire Strand
It looks like this means that I have a factory amplifier, but how can I wire up my aftermarket radio with these wires and get sound out of my speakers?
Wire Colors:
Brown
White/Red
Yellow
White/Orange
Green
Purple/White
Light Blue
Light Blue/Black
Metal Wire Strand
From this and your other post, kinda sounds like you need a factory service manual. Try searching for one on eBay. As for your stereo problem, if you buy a harness (I got mine at Walmart for $10) as if you were going to hook up to the factory harness, if I recall correctly the Walmart harness wires are the same colors as the factory wiring. If I recall correctly....
I found this on The Install Doctor - Radio Wire Harness and Colors - Ford Lincoln Mercury Hope it helps you.... Good luck!!!!!!!!
There is more detail on the web site......
Up To Late 1990’s
Ford/Lincoln/Mercury Radio Wire Harnesses
Note: using an optional snap on wire harness adapter will simplify the wiring. Most snap on wire harness adapters have already converted and color coded
the wires from the auto makers in dash wire harness to match typical aftermarket radio wire colors.
** The wire colors listed in the chart above are typical for these vehicles during these years but may not be the exact colors for this vehicle. This is another reason to use a snap on wire harness adapter. **
Typical Ford "Typical" New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Right Rear Spkr (-) Blue Purple w/ Black Stripe
B Right Rear Spkr (+) White w/ Blue Stripe Purple
C Right Front Spkr (-) White Gray w/ Black Stripe
D Right Front Spkr (+) Blue w/ White Stripe Gray
E Left Rear Spkr (-) Red w/ Blue Stripe Green w/ Black Stripe
F Left Rear Spkr (+) White w/ Blue Stripe Green
G Left Front Spkr (-) Blue w/ Orange Stripe White w/ Black Stripe
H Left Front Spkr (+) Purple White
I Amplifier Turn On Do Not Use For This Vehicle
J Power Antenna Turn On Do Not Use For This Vehicle
K Ground Wire Black Black
L Do Not Use For This Vehicle
M Dash Light Dimmer Wire Orange (if available)
N +12 Volt Ignition Wire Blue w/ Black Stripe Red
O Do Not Use For This Vehicle
P +12 Volt Battery Wire Blue w/ Red Stripe Yellow
Also from the12volt.com https://www.ford-trucks.com/forums/1...l#post12413147
<table border="0" cellpadding="3" cellspacing="1" align="center" bgcolor="#FFFFFF" width="100%"><tbody><tr><td colspan="2" class="redb">1992 Ford Explorer Stereo Wiring</td></tr> <tr bgcolor="#dddddd" valign="top"><td class="spce" width="50%">Constant 12V+</td><td class="spcel" width="50%">Green/Yellow </td> </tr> <tr bgcolor="#eeeeee" valign="top"><td class="spce">Switched 12V+</td> <td class="spcel">Yellow/Black </td> </tr> <tr bgcolor="#dddddd" valign="top"><td class="spce">Ground</td> <td class="spcel">Black </td> </tr> <tr bgcolor="#eeeeee" valign="top"><td class="spce">Illumination</td> <td class="spcel">Blue/Red </td> </tr> <tr bgcolor="#dddddd" valign="top"><td class="spce">Dimmer</td> <td class="spcel">n/a </td> </tr> <tr bgcolor="#eeeeee" valign="top"><td class="spce">Amplifier Remote</td> <td class="spcel">Blue </td> </tr> <tr bgcolor="#dddddd" valign="top"><td class="spce">Antenna</td> <td class="spcel">Right Front </td> </tr> <tr bgcolor="#eeeeee" valign="top"><td class="spce">Front Speakers</td> <td class="spcel">5" x 7" Doors</td> </tr> <tr bgcolor="#dddddd" valign="top"><td class="spce">Left Front (+)</td> <td class="spcel">Orange/Green </td> </tr> <tr bgcolor="#eeeeee" valign="top"><td class="spce">Left Front (-)</td> <td class="spcel">Blue/White </td> </tr> <tr bgcolor="#dddddd" valign="top"><td class="spce">Right Front (+)</td> <td class="spcel">White/Green </td> </tr> <tr bgcolor="#eeeeee" valign="top"><td class="spce">Right Front (-)</td> <td class="spcel">Green/Orange </td> </tr> <tr bgcolor="#dddddd" valign="top"><td class="spce">Rear Speakers</td> <td class="spcel">5" x 7" Rear Doors</td> </tr> <tr bgcolor="#eeeeee" valign="top"><td class="spce">Left Rear (+)</td> <td class="spcel">Pink/Green </td> </tr> <tr bgcolor="#dddddd" valign="top"><td class="spce">Left Rear (-)</td> <td class="spcel">Brown/Yellow </td> </tr> <tr bgcolor="#eeeeee" valign="top"><td class="spce">Right Rear (+)</td> <td class="spcel">Orange/Red </td> </tr> <tr bgcolor="#dddddd" valign="top"><td class="spce">Right Rear (-)</td> <td class="spcel">Black/White </td></tr></tbody></table>
Up To Late 1990’s
irishinontario
1997-2006 Expedition & Navigator
01-15-2014 08:33 PM
96anger
06-09-2009 08:52 PM
jpbrad0215
02-01-2007 11:36 PM
FghtinIrshNvrDie
07-02-2004 11:11 PM
