Power Steering Pump Pulley - Ford Truck Enthusiasts Forums
Old 10-25-2012, 11:14 AM
Tomboy Tomboy is offline
Tomboy is starting off with a positive reputation.
Trying to fix a chirping noise which seems to be coming from the power steering pump or pump pulley in my 86 F150 302 EFI. Tried lubricating the belt and the chirping goes away then returns. Planning to replace the pump and would also like to replace the pulley but have not been able to locate a new pulley. Is used the only option for a replacement pulley? Thanks for any helpful suggestions.
Old 10-25-2012, 11:49 AM
1986F150six 1986F150six is offline
1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold
Try to see if the pully(s) are in alignment with each other. Lubricant on a belt [belt dressing] is a "band aid" at best. Some have luck using emmory cloth to sand and roughen up the inside of the pully [with the belt removed] and then replace the belt.
Old 10-25-2012, 12:49 PM
81-F-150-Explorer 81-F-150-Explorer is offline
81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold
Your belt could have hardened up and it's no longer as flexible as it needs to be. Or the belt could be glazed.
I had this exact problem a couple of years ago. The belt was the culprit.
I'd try replacing just the belt first.
Old 10-25-2012, 07:19 PM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is online now
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
My father had a trick of laying a round rasp in a pulley and hitting it, lightly, with a hammer. Then he rotated the pulley and did it again, and again, until he had a light pattern of ridges in the pulley. It solved a whole lot of squeaks over the years.
Old 10-25-2012, 07:54 PM
TheKirbyMan's Avatar
TheKirbyMan TheKirbyMan is offline
TheKirbyMan has a good reputation on FTE.TheKirbyMan has a good reputation on FTE.
My PS pump belt constantly makes a chirping and squealing noise because the PO removed the AC bracket and put flat washers in its place. That bracket is what also aligns the PS pump side-to-side, so even though the washers are a close match, it's still off enough to cause noise.
power steering pulley installation tommyblack 2004 - 2008 F150 2 01-08-2015 01:02 PM
'05 powersteering issues FordFamily6 6.0L Power Stroke Diesel 1 12-06-2014 07:50 PM
Power Steering pump pully removal and install pete60hill 1973 - 1979 F-100 & Larger F-Series Trucks 6 06-27-2014 01:37 AM
power steering pulley question DonJuanDiego Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 3 06-03-2014 09:36 PM
Power Steering pump pulley DonJuanDiego 1968-2013 Full Size Vans 0 06-01-2014 10:19 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
