Lightning Instrument Cluster
I have an opportunity to get a '94 Lightning instrument cluster for my '95 F150. I checked my local Ford parts dept, and the instrument cluster P/N is the same for both the 94 and 95. Has anyone ever installed the Lightning cluster in a regular F-150? I want to do this mainly for the speedo. Thanks!
I THINK it doesn't work, otherwise many people would do that swap, but i'm not 100% sure.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster American Thunder Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Then theres:
99' Mustang GT 4.6L
88' F-250 Heavyduty 4x4 351/c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 with a
3 spd column shifter. Weighs around 7,000lbs w. 65mph top speed, who wants to race me!
Then theres:
99' Mustang GT 4.6L
I would also like to know the answer to this question.
Does anyone know if any other parts need to be transplanted so that the speedo will register correctly--like the VSS or the exciter ring???
Jon
1989 F-150 XL- 4x4, 302, M50D
1995 Bronco Eddie Bauer- 351W, E40D
Jon
The excitor ring and VSS are the same, the 120mph comes from the PSOM (programable speedo/odometer module). As far as I know, as I said before, they arn't compatible, otherwise i'm sure i'd of heard of that modification before.
Then theres:
99' Mustang GT 4.6L
Then theres:
99' Mustang GT 4.6L
The mileage isn't a problem, that can be programmed by the dealer, it's the fact that it don't work.
Then theres:
99' Mustang GT 4.6L
Then theres:
99' Mustang GT 4.6L
on
[updated:LAST EDITED ON 04-Sep-02 AT 04:37 AM (EST)]actually, according to the ford racing hotline it should work. the trucks have all the same inputs and the only difference is the variable for the mph(85 verses 120) in the psom or speedometer head.
they did say that you need to have a tach already as a factory option to do the swap and to get the cluster not just the speedo head. you can call them yourself at(586)486-1356 and verify this imformation.
just program in your tire size like your old psom.
Jim
P.S. the dealer does not do the mileage change but sends them out to a speedometer repair shop to have it done.
Jim
Well, as I said, I wasn't 100% sure, but pretty sure they dont match. However, you don't NEED to have a factory option tach, as the wiring for the tach is there whether your have one or not, the only difference between a tach vs tachless truck, is the PSOM doesn't have a tach in it, the plug is there.
That's it for mods now, saving for a Stang. Check out my Gallery for a look-see.
i love them, whether they are worth the 145 i paid w/ shipping, is something i try not to think about it. If you want to pay 130-140 for them, than sure. They fit great, look great, light is...about the same as stock, so the choice is up to you.
12valveEx
08-02-2015 08:07 PM
jonathan mosher
2004 - 2008 F150
07-11-2015 11:39 AM
Old Primer Red
11-04-2014 07:51 PM
95redbeast4x4
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
10-03-2010 09:07 PM
