460 E7TE on a F3TE Engine
You might check on the 460 board, but it seems to me you can't use carb heads on FI the manifolds are different. So if they are both FI heads your OK. Gas Mileage & 460 don't go together. The cheapest torque improvement is going with a 3 key timing chain set & advancing the cam 4 degrees past TDC. When I had my 6 F250 4x4 460 C-6 that was what I did & the increase was very noticeable plus I raised my vacuum to 17-19 inches at idle. The next improvement in torque came with a Hughes HD Towing torque converter.
Welcome to FTE & the Arizona Chapter. Where are you located?
Craig
Craig
460 E7TE Heads on an Engine that had F3TE Heads
Thanks for the reply Craig,
I'm in Tucson near Three Points. Both heads are off FI engines but the combustion chambers are configured slightly different and the intake valves on the E heads are 1.95 as opposed to 2.01 on the F heads. I had to nurse the truck home from New Mexico stopping every 20 miles or so and refill the cooling system after cool down. I know I got the engine very hot and when I pulled the heads, they were both cracked between the intake and exhaust valves on the front cylinders. The problem was the left bank head gasket and was given the E heads for replacement. Luckely, the engine block wasn't damaged and hopefully new gaskets and reworked heads will get me back on the road. Any more help you can give will sure be appreciated...................Ben
If my memory is correct there will be a compression difference. The 1.95s I believe will up your compression. which is a good thing for performance. Aren't the 1.95s a smaller combustion chamber?? I think so.
My mind is not as sharp as it once was. Since I sold my 86 F250 I don't stay on top of the 460 anymore. I moved my time to the Dodge V10 which I have & love in my Ford F250 replacement.
Craig
Craig
Gaskets
Thanks to all the replys,
According to everything I've researched about the two 460 heads, is they are interchangable with a slight difference in combustion chamber cc's. The big difference is in flow patterns and quench. I've decided to use the E7TE heads because I've got them and the F3TE heads are cracked between the intake and exhaust valves on both forward cylinders. With the intakes on the E7 heads being smaller, I hope to gain fuel mileage without lossing torque or horsepower. If not, oh well, the 460 is a torque engine anyway and at least I'll be back on the road.
The big question I'm putting out there is which gasket set do I use? The '91 for the E7 heads or the '94 for the engine? I don't think there's a difference, but I don't really know. Any help will be appreciated. I've already sent the heads to the shop..................Ben
Hey Bill, I went with Louie at Motorworks and Machine. He helped me with my '23 "T" Bucket build and rebuilt the engine in it when I spun the bearings. He's always been helpful, priced right and quick. As for the gaskets, I pulled a search on both Summit and Jegs and there seems to be a break between '92 & '93 and I'm putting '91 heads on a '94 block. The heads are supposedly interchangable yet neither site shows a head set for a '94 that even looks close to my application. The FelPro '91 HS8558PT6 looks exactly like what I pulled of but the application detail shows an end year of '92. I'm more confussed now than ever.....................Ben
I would inspect every little thing, every water jacket, every oil passage, to make SURE they all align up to your block or your old head, check all sides, intake, exhaust and surface of the head just to be sure gaskets don't cover anything important.
i would worry less about the combustion chamber size.
E7te vs f3te 460 heads
Had a broken exhaust port on a F3 head got some e7. The e7 didn't come with rockers or push rods can I use the f3 stuff on e7 heads. The valve guide is larger on e7 than f3. Have umbrella seals the positive seals won't fit on the e7 guides that's 16mm outside diameter the positive seals have inner diameter of 12mm. Any input would be great
crm318
49
07-24-2023 11:05 PM
Acab1
08-23-2016 08:15 AM
YoungFordAddict66
12-22-2008 10:39 PM
