Manual Hubs
I know lock out hub units are available for solid front axles.
http://spyntec.com/
Expensive = 1500.00 or so
The 4x4 F-150's use a CV joint whereas solid axles and the older Ford IFS axles used universal joints. I'm not certain that a manual locking hub is even possible on a CV axle.
I like not having a hub to pull apart every 30K miles to repack wheel bearings and re-grease the components in the hubs.
It's possible, Toyota did it on their Tacomas for a long time.
I think simple is better, which is why I'm going to buy a Sd next time. That way I can get a manual T-case and manual hubs.
ETA, I see you have a '99, that system is totally different than the 04+. On yours vacuum pressure locks the front end so if you loose vacuum pressure you have no 4x4. On the newer trucks vacuum pressure keeps the front axle unlocked so if you loose vacuum pressure the axle locks. This is all good in theory, but Ford designed it so each hub is independant, so most of the time you end up with one hub loosing vacuum pressure and trying to lock while the other stays unlocked. Then you get an expensive repair bill to replace the IWE with the stripped teeth because it was trying to do the opposite of the other hub.
I realize that the 97-03 and 04-08 09-13 uses different systems. But all are based on similar principals when compared to pre 97's.
I honestly have not heard of many people with issues on the vacuum operated 4x4... at least on the 97-03 boards. Maybe 1-2 cases.
Maybe its more prominent on the newer stuff.
regardless i agree that you ought to get a SD if you want lockouts....
Interesting post, considering that while I was out in the pouring down rain tonight, my hubs would not lock. I have only had this 2010 for a few months, but I was thinking the same thing, "simpler is better" , and wondered about doing manual locks too. Extended warranty should cover it, but that doesn't matter if it's not there when you need it
jshad101
19
12-07-2014 10:44 AM
schmitty99
06-02-2012 09:40 AM
