Will the Power Steering for a 55 Sedan Fit on a 55 F100?
Does anybody know if a 1955 Ford Sedan's power steering unit will transplant over to a 1955 F100? They both have Y-block engines, but I am not sure of the steering geometry for the lower power ram assembly. If anybody has made this switch, I would appreciate hearing about it. Thanks, Jag
1955 (1953/64 full sized Fords) came with Power Assist P/S, have a separate control valve and ram cylinder. The manual steering gearbox is used, because it has nothing to do with Power Assist.
Two long P/S steering hoses, pressure and return, route from the pump to the control valve. Two short P/S hoses, pressure and return, route from the control valve to the ram cylinder.
F100's were not available with P/S until 1966.
Many moons ago, Preston Ledbetter (ex Ford partsguy and owner of F100 Parts Unlimited in San Jose) converted 1953/56 F100's to power steering by using 1953/60 Ford Passenger Car Power Assist P/S.
He cut the trucks draglink, threaded it to accept the control valve (has large female threads that 1961/64 control valves don't have), then mounted the ram cylinder within the linkage.
Used 1953/64 (1965 Mustang w/a generator) Eaton P/S pumps with Y block brackets and P/S pulley. Used the Y block accessory outer pulley that bolts to the harmonic balancer for the P/S belt.
Eaton P/S pumps have a separate reservoir that mounts atop it, or when installed on 1955/57 T-Birds, have a remote mounted reservoir on the left fender inner apron. This reservoir was also used on 1960/64 Galaxies with A/C.
Preston died 10 or so years ago, and it's been too many moons for me to recall what else the conversion entailed. The only other person I'm aware of in this forum that knew Preston was Julie, but he's no longer an FTE member.
C2AZ-3A533-A .. Control Valve Ball Stud Repair Kit-All 1961/80 FoMoCo Passenger Cars with Power Assist P/S.
scott292y
41
09-27-2023 02:18 PM
sierraben
17
01-02-2007 10:09 AM
Tainted
12-27-2006 03:17 PM
