what is it
what is it
This is a 1997 351w motor and i was wondering if someone knew what this was without taking a pic of it,if you stand in front of the truck it would be on the left side of the coil,and it has a few electrical wires and two vacum lines going into it.it also has a round cap at the top and it turns but not sure if it comes off, but what is it and what does it do.Thanks
For reference: Fuel Injection Technical Library » EGR Vacuum Regulator (EVR)
Another shot here:
Check the EGR valve to make sure it opens and closes. Ay idle, apply vacuum to the port, the truck should stall, or just about. If that checks out, then check to see if the vac line has vacuum at idle. If it does, its probably bad, if not the valve may be stuck partially open
Funkykolemedina
34
05-06-2021 04:03 AM
JLmissouri
09-09-2018 01:55 PM
wintertruck87
28
11-21-2014 10:34 AM
erupert66
15
01-07-2013 04:53 PM
RiverPirate
15
12-01-2011 01:00 AM
