High altitude - Ford Truck Enthusiasts Forums
High altitude
Old 10-23-2012, 08:04 AM
uscgmkcret03 uscgmkcret03 is offline
uscgmkcret03 is starting off with a positive reputation.
High altitude
I am looking at a relocation possibly this spring, may be moving to a location of approx 10,000 ft in Colorado. Where I'm at now is around 1000ft.
Wondering if for those who have traveled thru or for folks that may live at these altitudes if you notice any changes in performance in our trucks.
Thx
Old 10-23-2012, 10:32 AM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Thx
I've not driven at high altitudes with my 6.7L truck, but I've been through the mountains with other diesel trucks. Power dropped off some, but the most noticeable difference was the increase in turbo lag.
Chevy vs. Ford in Heavy-Duty Rumble in the Rockies - PickupTrucks.com News
Old 10-23-2012, 12:25 PM
cummins cowboy's Avatar
cummins cowboy cummins cowboy is offline
cummins cowboy is gaining momentum as a positive member of FTE.
I wouldn't worry about it I drive my truck exclusively at 4k feet and above to 10k some say our engines don't compare well to chevy at altitude, I don't know if thats it or the truck just defuels at highway speeds.
Old 10-23-2012, 03:06 PM
Painted Horse's Avatar
Painted Horse Painted Horse is offline
Painted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud of
Like Cowboy, I live at 4500 foot and often tow my horses to trail heads in the 8,000 to 10,000 foot range. Don't notice any problems. Just go and enjoy it.
It's not like the old days of carburators, where you had to rejet your carbs to match with the elevation. PCM in the truck reads the barometric pressure and adjust the fuel accordingly.
Old 10-23-2012, 05:49 PM
_red rocket_'s Avatar
_red rocket_ _red rocket_ is offline
_red rocket_ is gaining momentum as a positive member of FTE._red rocket_ is gaining momentum as a positive member of FTE.
I live at 7700 ft and constantly run down the hill to Denver and back, mostly unloaded. 65 - 75 mph up the hill and still room to go much faster but this is unloaded. With my TT in tow, no problem at all up the hill at 65 mph with again, still room to go faster but no reason to in tow so I don't. Been as high as 9k with it and ran fine.
You going to Leadville? I've not had it up to 10k yet, or through Eisenhower tunnel but I am not concerned...it runs great. Should be up and over Loveland pass soon but work responsibilities
Old 10-23-2012, 06:22 PM
kper05's Avatar
kper05 kper05 is offline
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
Quote:
Seems like I remember FoMoCo offering an improvement with the 2012's in this category.
Old 10-23-2012, 06:50 PM
Hdslider's Avatar
Hdslider Hdslider is offline
Hdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputation
Kper. I believe you are correct. I just cant place exactly what they did.
Old 10-24-2012, 12:30 AM
mrjc's Avatar
mrjc mrjc is offline
mrjc has a good reputation on FTE.mrjc has a good reputation on FTE.mrjc has a good reputation on FTE.
I live in col springs at 6700 ft. Pull the 5er all over the place here and notice no power drop, if i compare my 2012 to my 07 6.0l, it outpreforms it at altitude hands down. We drive to the top of pikes peak 12,000 ft regularly and my old 6.0l bucked towards the top every time. Seems the turbo was starved for air and produced a surging throttle i couldnt control. The twin turbo is smooth as silk up top the peak with no bucking or surging. As mentioned above, maybe a high altitude improvement was made in the 2012s. My truck pulls hard up ute pass here which is a twisty climb up to 10k feet with our loaded toyhauler.....the new truck sips fuel up here compared to my old 6.0 which drank a half tank here to the camping spot. New truck only uses an 1/4 tank.
Old 10-24-2012, 05:58 AM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
I used to live on Colo and have driven all over it. You will be fine. I never really noticed any drop off.
Old 10-24-2012, 06:54 AM
Tom's Avatar
I'd like to point out that there was never really any deficiency at altitude, just that it didn't pull quite as well as the Silverado. Lots of folks here in the 6.7L forum took umbrage to the fact that the Silverado won this test, but remember that they were pulling 18,920 lbs of trailer up the nastiest interestate mountain grade in the country.
I've pulled up to the Eisenhower tunnel loaded heavy before, and it was the only time I've ever overheated a truck. The cooling system was working just fine though, the cooling fan just couldn't move enough air through the radiator to keep that thing cool. The grade is that bad. A 42 MPH average speed is really good for being that heavy up that hill.
I'm absolutely certain that there is power loss at altitude. But it's really not that bad, and nowhere near the power loss a non-turbo engine would have.
Old 10-24-2012, 07:42 AM
Hdslider's Avatar
Ive been thru eisehower tunnel more time than i can count. Yes you will loose power. All you gotta do is get out and try walking around. Alot of folks need oxygen that high. Well our diesel is the same way.it would love to have more air. But i dont need to go any faster going up. Im more. Concerned going down. You wont have problems.
Old 10-24-2012, 01:26 PM
jetpilot2's Avatar
jetpilot2 jetpilot2 is offline
jetpilot2 is a splendid one to beholdjetpilot2 is a splendid one to beholdjetpilot2 is a splendid one to beholdjetpilot2 is a splendid one to beholdjetpilot2 is a splendid one to beholdjetpilot2 is a splendid one to beholdjetpilot2 is a splendid one to behold
I just pulled from coast-to-coast and I definitely noticed a difference in performance when running through some of the mountains. More than once I was questioning whether something was wrong, but I'm also pulling 18,000 pounds. After a couple times of that, I noticed it was always at altitude and pulling grades.
I'm glad I only have to do that once a year! And this is MY experience only.
Old 10-24-2012, 11:51 PM
Yes to Leadville.
Just got home from a quick recon trip to area to check things out, awesome country.. Wish I would have had more time to explore, Flew into Denver Monday night, drove to Leadville and back to Denver Tues, flew out Wed morn.
By watching a couple 6.7's blow by my 6 cyl rental going up to the Eisenhower tunnel, I decided that getting up will not be as big of issue as dropping down loaded could be.
Old 10-25-2012, 12:01 AM
azking_Ranch's Avatar
azking_Ranch azking_Ranch is offline
azking_Ranch has a very good reputation on FTE.azking_Ranch has a very good reputation on FTE.azking_Ranch has a very good reputation on FTE.
Yea beautiful country, miss Colorado.
Old 10-25-2012, 05:58 AM
senix's Avatar
Yes to Leadville.
Leadville is so nice...lucky man! I have lived in Grand Junction, Pueblo and the springs..family in Denver.
Do it!
Ecoboost towing at high altitudes tmehrkam EcoBoost (all engine sizes) 15 03-11-2012 09:17 PM
Code 171 & 174???? carddog24 1997 - 2003 F150 6 02-10-2012 06:44 PM
01 won't start at altitude? Phoenixson 1999 - 2003 7.3L Power Stroke Diesel 9 10-08-2008 12:09 AM
carburetor altitude adjustment crashbox455 Fuel Injection, Carburetion & Fuel System 10 11-23-2005 06:40 AM
7.3L IDI diesel at high altitude ctann 1987 - 1996 F150 & Larger F-Series Trucks 0 08-06-2003 01:49 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
