2000 F150 turns over but won't start - Ford Truck Enthusiasts Forums
Old 10-22-2012, 07:20 PM
truedouble truedouble is offline
truedouble is starting off with a positive reputation.
My 2000 Ford F150 will turn over but won't start. I can spray a little starting fluid in and it will run for a second or two, so I'm thinking it might be the fuel pump, or the relay. I loaned it to my daughter, and thankfully it quit in her driveway and not on the road! Any suggestions on what to check first? It is a 4.6L V-8 2 wheel drive.
Steve Fowler - GA
Old 10-22-2012, 10:45 PM
enriched&beyound's Avatar
enriched&beyound enriched&beyound is offline
enriched&beyound is starting off with a positive reputation.
fuel pressure needs to be checked.
but yeah check those relays and fuses too
Old 10-23-2012, 07:39 PM
Thanks!
Thanks for taking time to answer my post. I checked the relay/fuse today, and listened for the fuel pump to come on, which it did. After a little bit, I depressed the gas pedal about 3 times and turned it over and it cranked. I don't remember the last time I changed the fuel filter. Could that be the problem?
Thanks,
Steve Fowler - GA
Old 10-23-2012, 09:22 PM
redwood's Avatar
redwood redwood is offline
redwood is gaining momentum as a positive member of FTE.
Mine is not starting intermittently. I've checked the fuel rail when it does it and there is no pressure. If I keep rocking the ignition off to on and the pump will eventually kick on and it'll start fine. When I figured this much out, I ordered a pump, screen, and filter. I'd say you're looking at the same thing.....
As a side note, I checked the relays and fuses. Everything tested good. The last time I had a fuel pump go out on this generation truck it did the same exact thing.
Old 10-24-2012, 05:27 PM
Quote:
Thanks,
Steve Fowler - GA
Steve
Yes it can be the problem a new fuel filter certainly could not hurt....even if it really doesn't improve the situation.... At least you know that the filter has been covered. it is not a big expense.
have you cleaned your MAF sensor? if not, be sure to use cleaner safe for MAF sensors.
After changing the fuel filter and cleaning the MAF sensor. The nest step is to test the fuel pressure.
Won't start Kevin Matthews 1987 - 1996 F150 & Larger F-Series Trucks 0 09-07-2015 01:44 PM
2004 F150 won't turn over..help nela808 Modular V8 (4.6L, 5.4L) 1 06-11-2015 08:28 AM
95 f150 wont start ss27gogeta 1987 - 1996 F150 & Larger F-Series Trucks 6 02-20-2015 10:16 PM
1996 F150, 5.0/302 starts most of the time but sometimes won't. blwtide1 1987 - 1996 F150 & Larger F-Series Trucks 14 11-05-2012 08:28 PM
1996 F150 - Starts most times, and sometimes won't blwtide1 1987 - 1996 F150 & Larger F-Series Trucks 1 09-20-2012 02:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
