4.9 valve clatter - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
4.9 valve clatter
Old 10-22-2012, 06:07 PM
Cowcharge Cowcharge is offline
Cowcharge is starting off with a positive reputation.
4.9 valve clatter
Hey all, '94 e150 with a 4.9l 6, 190k. Doesn't use any oil and mostly runs ok. The valves don't make any noise at idle, while accelerating or decelerating. But when going down a hill (especially at highway speed), and the van "catches up with the engine" so there's no load, there's a godawful clattering until I either let off a bit or give it enough gas to put a load on the engine again. Any idea what would cause that? Thanks!
Old 10-22-2012, 10:32 PM
joshofalltrades joshofalltrades is offline
joshofalltrades has a good reputation on FTE.joshofalltrades has a good reputation on FTE.
sounds like it may need new lifters. or you could try a can of seafoam or whatever to hope it'll loosen up your existing lifters - but new would be best. they're not too bad to install.
Old 10-23-2012, 02:00 AM
pacific350 pacific350 is offline
pacific350 is starting off with a positive reputation.
Normally I'd think weak springs from too much heat like some days of a bad radiator or bad gas which all ethanol is in my book or too low of an octane.
It's not me doing the job so I won't suggest looking under the vavle covers to see whats up
Old 10-23-2012, 02:04 AM
if he looks into changing the lifters, he'll have the valve cover off in the process, and at least take a look around. i've put 300s through hell and never had a valve spring problem, nor have i heard of it being a common problem with 300s. but i have had lifter problems on them
1980F150 valve clattering 1980 Bullnose 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 07-13-2014 01:44 PM
Clitter clatter noise near exhaust manifold F-erOnlyRunsDwnhill 1987 - 1996 F150 & Larger F-Series Trucks 11 04-03-2014 11:37 PM
timing will not stay set 96 4.9 rdsjw967 1987 - 1996 F150 & Larger F-Series Trucks 5 07-08-2012 09:35 AM
4.9 Owner Requesting Help WH90 Ford Inline Six, 200, 250, 4.9L / 300 20 10-26-2008 06:39 PM
Valve Train Noise pb12001 Ford Inline Six, 200, 250, 4.9L / 300 8 03-01-2002 02:21 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
