Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 10-22-2012, 01:41 PM
jhfishdad jhfishdad is offline
Garage is empty, add now
jhfishdad is starting off with a positive reputation.
facebook.com/jhfishdad
Expedition towing power loss, no codes
Have a 2003 XLT 4.6L Expedition (160,000mi) that has been awesome, but recently began loosing power at speeds over 45mph (rpms >3000) when towing boat up hill in GA (overdrive off). Runs & shifts smooth w/ no miss fires. Large EGR vacuum line blows off when I floor the gas, but no codes to go by. Researched most forums and can't find answers. I hope you can help.
Here are my readings at idle (and with ACTRON scanner):
EGR line pressure ~ 2PSI (this seems normal back pressure at idle)
idle vacuum test 19psi, increases with higher rpms (no vacuum leaks).
Oxygen Bank 1: 02S11 0.4V, 02S12 0.8V
Oxygen Bank 2: 02S21 0.3V, 02S22 0.7
MAF flow 4.6, Coolant temp: 179 F,
FUEL system 1 closed loop: ST FTRM 3.9%, LTFTRM 7.8%
I ordered an ELMSCAN 5 OBD reader to test engine more before replacing catalytic converters.
Q1) I suspected catalytic converter after it gets hot but how do I test it, what should I look for? When cool the back pressure appears normal.
Q2) How do I find out factory specs on oxygen sensors? they seem ok.
Q3) Does the 2003 Expy have baby cat-convertors or normal ones? I heard baby cats send different signals to computer than normal ones (can't find factory specs).
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
