Fuel pump does not come on with ignition switch - Ford Truck Enthusiasts Forums
Old 10-22-2012, 01:49 PM
hackmoremam hackmoremam is offline
hackmoremam is starting off with a positive reputation.
Hello, can anyone tell me if the fuel pump operation is controlled thru the ignition switch on a 93 f-150 - 4.9l?
While driving last week smoke started coming from under the D/S dash and then the engine quit.
When I got it home I noticed the fuel pump does not come on when the switch is turned on.
Fuel pump runs when jumped at the fuel relay socket.
Where do I go next? Help - Please.
Old 10-22-2012, 02:32 PM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Replace the PCM computer.
Old 10-22-2012, 02:55 PM
Hey, thanks subford. I was really trying all options to avoid that but I guess I'm going to have to bit the bullet.
Is that still the case if I have 12 volts at the "voltage-all-the-time" pin in the Fuel pump relay socket and when I turn the switch on I get 12 volts at relay-on pin - but it doesn't time out - it stays on.
Is that also a symptom of a bad PCM?
Old 10-22-2012, 03:15 PM
subford's Avatar
Yes it is.
Old 10-22-2012, 03:29 PM
How about smoke coming from under the D/S dash.
Could the PCM have beltched smoke?
I've taken the cluster and the fuse block out and haven't seen any damage at all. I can only see a small amount of the PCM cover and I can't see all the wires in that corner without pulling some major stuff out of the way.
Old 10-22-2012, 03:34 PM
subford's Avatar
Yes that is where the smoke came from.
You will have to take the computer out and open it up to see the burnt item that let the smoke out.
The computer comes out from under the hood and is located in the drivers kick panel on your 93.
Old 10-22-2012, 03:54 PM
subford's Avatar
By the way you have to take the small screws out that attach the fender to the inter fender and pry the inter fender back with a broom handle.
The center bolt in the plug is a 10mm and you back it out and wiggle the plug as you do. Then there are two small nuts one above and one below the computer plug to take off.
Pull the rubber retainer that is round the computer socket off that was being held on by the two small nuts.
Then just pull and wiggle the computer out.
Old 10-23-2012, 05:42 AM
Thanks, you'all have been unbelievably helpfull. I won't be able to work on the truck again until this weekend. I'll follow-up and with the results.
Thanks Again!
Old 10-29-2012, 08:38 AM
Hey Subford, You were right on target. I put a new PCM in and it cranked and runs better than ever.
This is the first time I have ever used a forum but it won't be the last. I hope I will be able to return the favor someday.
Thanks again.
Fuel pump voltage low? motoboy 1999 to 2016 Super Duty 2 12-17-2016 09:23 PM
electric fuel pump conversion question 1979 300i6 1973 - 1979 F-100 & Larger F-Series Trucks 5 08-26-2014 09:50 PM
Hooking up fuel shutoff solenoid flainn Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 13 09-23-2012 04:43 PM
1989 Ford F-150 Starting Problems wjschaller 1987 - 1996 F150 & Larger F-Series Trucks 1 03-21-2009 04:43 PM
87 fuel system electrical NicksF250 1987 - 1996 F150 & Larger F-Series Trucks 1 05-24-2008 06:44 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
