Installing Interior Grab Handles
Thanks guys.
My wife is about 5' 6" and she can reach these without too much trouble. Bill you might think about putting the handle on the A pillar itself (by the windshield) if this is too high.
At some point I hope to build a set of step bars for the truck as well, but that is a long way down the "to do" list. Got to get some bodywork done ahead of that. I like the design of the N-Fab bars, but I don't like the way they attach and the fact that they hit the bed if you flex the truck very much. I intend to build something similar and fasten them to the frame instead of the rockers.
Ha ha! Same here. But I have the added bonus of 'needing' to reach over and shift every now and then!
Nate,
Thanks for the "Grab Handle" info, it is a project I plan to do very soon on my 96 F-250.
The well nuts you used is the last bit of info I needed. It is was so obvious when you mentioned them. I think I even have a few laying around.
"Kudos" for finding the answer.
Thanks again, Mike
Thanks again, Mike
your setup looks GREAT!!!! Kudos!
There is also an article over on the .org or maybe its here where a guy used ford explorer handles and well nuts to mount handles in his OBS...found link
http://www.powerstroke.org/forum/94-...ndles-obs.html
Kinda curious cuz ive seen those A-pillar handle mounts too... Just didnt think there was much 'meat' there for them to grab anything.
Great job tho Nate! (I tend to read threads once or twice and keep up with them, but never actually post them until some RANDOM thought jumps in my head... then i forget to actually comment on the OP topic. lol SORRY)
#28
A little update to this old thread. I did another set of these in my new truck and used 1/4 x 20 clip nuts instead of rubber well nuts. Not only are the clip nuts cheaper to buy but they seem to be a lot more sturdy and reliable IMO. I had to drill 2 holes per attachment point, and one of them had to be pretty (around 7/8") to allow the clip nut to slip through it, but I think this is the better way to accomplish this installation. The well nuts are a real pain to get seated correctly and if you ever have to remove the handles for any reason, then you run the risk of losing the well nut down inside the cavity in the pillar. The clip nuts just hang on there like they should.
Another word of caution is to look under the plastic trim before you start drilling your holes. The cabs are not all built the same and you may have to fudge the holes one way or another to make the holes fall where there is a good place to drill. The other thing I started doing that really speeds the installation was to mark out the locations for the holes on the plastic trim with a pencil, then pull the screws out of it and look to be sure that it was a good location in the steel for the holes (there are a lot of things up in that part of the pillar that you need to work around to make it fit) then if everything looked good, I put the plastic trim back on, put the screws in and then drilled through the plastic and the metal both with a small pilot bit. That ensures that the holes will line up like they should when you're all done. That eliminates a lot of measuring and room for error.
This really is, IMO one of the better interior mods for these trucks especially if it is a lifted truck or F350 and you have kids or a relatively short wife (of which I have both).
The following users liked this post:
dmccorkle911
32
10-07-2023 09:07 AM
IIGood
04-04-2015 09:15 PM
79F250isalive!
02-27-2015 05:59 PM
