1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
shutter when towing.
Old 10-22-2012, 07:06 AM
geedo's Avatar
geedo
geedo is offline
Question shutter when towing.
Just bought a 2012 f350 diesel and started towing my 5er after 900 miles. Between 1st and 2nd gear i experience a shutter. After that its smooth through 6th. Any Ideas
Old 10-22-2012, 09:28 AM
spud57's Avatar
spud57
spud57 is offline
That would probably be a drive-line shudder caused by the angle change of your drive shaft with the weight of your trailer. Best bang for your buck is to add air bags to keep the truck height the same without the trailer. Fixed mine.
There are ways to shim the carrier bearing but you will probably end up with a shudder unloaded.
S
Old 10-22-2012, 09:48 AM
P.Bronner's Avatar
P.Bronner
P.Bronner is offline
Spud is correct, it IS a driveline shudder caused by the angularity changes that occur when the truck is loaded. Air bags will eliminate a lot of the problem, as stated above. I have them on my truck. Shimming the center driveshaft support will make the problem worse. That was the fix on earlier superduties but not this one. The center support bracket needs to be made SHORTER. I cut mine down by about 5/8" and eliminated nearly all the shudder, with no negative side effect (in the form of an unloaded high-speed vibration). I tried shimming down and the problem got noticeably worse. I have read that Ford now has a re-engineered replacement driveshaft that cures the problem, but will likely not partake as I have fixed mine to my personal satisfaction.
Old 10-22-2012, 02:37 PM
geedo's Avatar
geedo
geedo is offline
Shutter when towing
Thanks for the reply's. Your suggestions sound logical but if don't anything will harm the vechichle?
Old 10-22-2012, 08:11 PM
spud57's Avatar
spud57
spud57 is offline
If you can live with it I don't think there is any harm. I put the air bags on for two reasons 1. too much sag 2. the vibration.
S
pdqracer
2009 - 2014 F150
08-15-2019 08:16 PM
echo_17268
2017+ Super Duty
62
03-26-2018 01:57 PM
J&JProperty
05-14-2010 09:54 PM
PSDx3
02-01-2009 03:19 PM
mwelch1169
6.4L Power Stroke Diesel
08-22-2007 03:28 PM
Quick Reply: shutter when towing.
