Oil cooler question - Ford Truck Enthusiasts Forums
Oil cooler question
Old 10-21-2012, 09:03 PM
wingrider75 wingrider75 is offline
wingrider75 is starting off with a positive reputation.
Oil cooler question
I just did an EGR delete, new PMM Lifetime Oil Cooler, complete flush, and coolant filter (among other updates) on my dad's early 04. The old oil cooler was so plugged that you couldn't blow air through it, and the EGR cooler blew out (lots of white smoke). The deltas on the ECT/EOT are starting to climb back up again. After I first got it running again, the deltas were running around 5 degrees, the other day they were up around 15-20. ECT was 188-192 and EOT was 205-212. Has anyone else used the PMM cooler, and what are your deltas running? I'm afraid this thing's plugging up again, even with the flush and coolant filter. Any thoughts?
Old 10-21-2012, 11:16 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is online now
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
Not familiar with the PMM lifetime oil cooler... is that a new design?
At any rate it looks like your cooler is plugged. Did you flush before or after all the work was done?
Josh
Old 10-22-2012, 01:44 AM
Yahiko's Avatar
Yahiko Yahiko is offline
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
Do some search on PMM and you may find something
Sean
Old 10-22-2012, 10:57 PM
Flushed after. I didn't have much choice. The egr cooler was blown and leaking into the intake like crazy. Think I'm lucky it didn't hydrolock on me. I found stuff about PMM but not much about their oil cooler.
Old 10-22-2012, 10:58 PM
Actually what worries me about the cooler is that it has disappeared from their website now.
Old 10-23-2012, 12:12 AM
amdriven2liv's Avatar
amdriven2liv amdriven2liv is offline
I'm hitting easy street
amdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputation
Seems that a past post talked about having larger passages through the cooler. Thus, it doesn't reduce the temp of oil as well as the OEM oil cooler does.
I'll see if I can find that post.
Old 10-23-2012, 12:19 AM
Oops, I might have been thinking about another one. IPR research had a new oil cooler that did that. Not sure where PMM has gotten theirs from.
Did their packaging or info call it a "high flow" oil cooler per chance?
Where do I go now? EOT vs ECT 2006powerstroke90 6.0L Power Stroke Diesel 30 10-17-2016 03:20 PM
03 6.0 Delta issues 2000 Ex-cursion Excursion - King of SUVs 14 08-31-2016 07:51 AM
03 6.0 Excursion Delta issues 2000 Ex-cursion 6.0L Power Stroke Diesel 7 06-29-2016 01:25 PM
Just replaced oil cooler again, still high delta vatreefarmer 6.0L Power Stroke Diesel 71 08-09-2014 08:48 AM
My dealership coolant flush experience ... So far Mattb60 6.0L Power Stroke Diesel 18 07-28-2013 01:27 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
