74 F350 Auxiliary Gas Sending Unit/Gas Gauge Help - Ford Truck Enthusiasts Forums
Old 10-21-2012, 08:46 PM
74 F350 SCS's Avatar
74 F350 SCS 74 F350 SCS is offline
74 F350 SCS is gaining momentum as a positive member of FTE.74 F350 SCS is gaining momentum as a positive member of FTE.
Hi- I have a 74 F350 reg. cab Super Camper Special w/460 and C6. I decided to remove my midship (auxiliary) gas tank today to clean it out. I am going to be installing a new carb soon and wanted to make sure the tanks are clean before doing so. I was shocked to see how clean the inside of the tank was and the gas in it was extremely clean. I cleaned it out and replaced the rubber fuel lines. The fuel gauge used to work intermittently on the auxiliary but always worked on the main. Just recently the fuel gauge stopped working on both. I removed the fuel sending unit and it looks greats and appears functional. The float appears good, connecting wire is intact, but no sock. The outside connector to the sending unit appears to be in good shape too and not corroded. Any ideas of what I should look for to see why the fuel gauge no longer work? Thanks for your help.
Old 10-21-2012, 10:02 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is online now
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
Ground the wire that goes to the fuel sender, turn the ignition to the "run" position. The needle should swing all the way to "full". If it does then either the sending unit is bad or the sender's ground connection is bad.
EDIT:
DUHH!, The way I wrote that it sounds like you ground the wire on the pigtail that plugs into the sending unit, you don't. What I meant to say was to ground the wire that comes from the gauge, where it plugs into the pigtail.
Old 10-21-2012, 10:07 PM
KIKKUP's Avatar
KIKKUP KIKKUP is offline
KIKKUP is gaining momentum as a positive member of FTE.KIKKUP is gaining momentum as a positive member of FTE.
Old 10-22-2012, 12:06 PM
Hey Mike and Kikkup, thanks for the information and resources. Exactly what I was looking for. I'll start my troubleshooting efforts this weekend.
Thanks,
new fuel gauge float unit not working jim collins 1973 - 1979 F-100 & Larger F-Series Trucks 7 10-10-2015 09:25 PM
ford sending unit fuel hand dcelrod 1994.5 - 1997 7.3L Power Stroke Diesel 8 05-04-2015 04:58 PM
Gas and Temperature Gauge Issues JD_F100 1967 - 1972 F-100 & Larger F-Series Trucks 26 08-31-2014 11:26 AM
Testing Sending Unit JamesHendrix 1973 - 1979 F-100 & Larger F-Series Trucks 2 05-27-2014 09:31 PM
gas gauge diagnostic help filthy6 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 05-01-2014 10:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
