'71 F100 Build
#31
#32
dave i think on those you need to find and drill the spot welds out.. then when you get the new stands if you dont have a spot welder you can drill holes and button hole weld em back in.. just be sure of the exact alignment before final welding.. shims can correct some for fender alignment
#34
#35
#37
Here's some more pictures. I apologize for some of the shots - I'll replace them with better ones as soon as I can.
Rust on the radiator support...
Passenger side front cab mount
Today's progress...
Parts!
As I started uploading the pictures, it occurred to me that I ought to do the tie rod ends and front brakes while I have the front end torn up. There's lots of room to work under there now.
Today's progress...
Parts!
#40
Alan - I'm not complaining one bit. My last "project" was a '66 Dodge 1/2 ton. The more I cleaned it up, the worse it got. By the time I got ready to start on it I found that substantial portions of the rockers, floors, and forward part of the cowl had rotted out. Even worse was the fact that there was no aftermarket part support and finding a parts truck with a decent cab was all but impossible to find.
This time around I have a solid cab and parts are available for what needs fixing. This project is certainly easier than my other attempt at a project truck.
#43
I managed to make just a bit of progress this afternoon and I still haven't found anything worth throwing in the towel about.
The front end is now up in the air. I used one set of jack stands under the front axle to support the chassis. I then jacked up the corners of the cab and supported them with a second set of jack stands.
I tried eyeballing the body lines between the cab and the bed as I raised the front of the cab. I think I've got them pretty close.
Driver's side cab mount after lifting the cab.
Passenger side cab mount after lifting the cab.
Ummm RC - Is that a welded tie rod end?
Another effect of raising the cab - the clutch pedal now comes all the way back up!
I thought about getting the hood and inners out, but with rain in the forecast for the next couple of days I decided to leave them be. I did have Nikki bring the fenders in to the garage. If it starts raining on my parade, I can work on getting the fenders ready.
#44
#45
