2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Licence plate light bulb replacement 2007 Expedition
Old 03-20-2015, 08:08 PM
sandroost's Avatar
sandroost
sandroost is offline
I'm in the process of fixing up a used Expo that I recently purchased. Among the little things I need to address is only one of the licence plate lights doesn't work, and I don't want to be pulled over when that one goes out...
These light covers look to be held in with a phillips screw, but for some reason neither one will back out, nor tighten?? I assume that either they are stripped or have a nut on the backside?
Something so simple as a plate light looks to be a big dig now.
Any advice on how to access and replace these lights would be greatly appreciated!
Old 03-21-2015, 05:02 PM
sandroost's Avatar
sandroost
So I figured out how to access them- just prise out the expanding moly bolt like thingy as the plastic screws were ineffectual.
Good news/bad news is the side that works apparently has a leak as the bulb cover had been full of water often over the years, but at least it lit up. The side that doesn't work must have a wiring issue under the hatch "grill", but the cover at least seals out the water.
I switched out covers and put a new bulb in and at least one side works well- for now.
Old 03-24-2015, 11:58 PM
mot250's Avatar
mot250
mot250 is offline
Those plastic screws and expanders are a good idea in theory but suck in real life, don't they? I removed mine by prying up on the underside of the screw head with a small flat blade screwdriver while turning the screw head with a Phillips screwdriver. I put in a new plastic screw and expander but I think it will be just as hard next time I need to get it out.
Ford'05HG
1997-2006 Expedition & Navigator
01-09-2013 12:21 AM
acf6
1999 to 2016 Super Duty
11-18-2012 04:10 AM
Leonandlisa
6.4L Power Stroke Diesel
08-02-2011 02:58 PM
phil92xlt
1983 - 2012 Ranger & B-Series
03-28-2010 07:10 AM
maticuno
02-18-2004 07:35 AM
Quick Reply: Licence plate light bulb replacement 2007 Expedition
