Running wires under carpet? 2012 F 250
I want to run a couple of wires from the Upfitter Switches to the left front underside of the bed. I understand that there are rubber plugs in the front and rear of the lower corners of the crew cab.
I would like to run the wires along the side under the carpet from front to rear. So how does one remove the inside moldings to be able to get wires under the carpet?
Hopefuly someone here has conquered that challenge and is willing to share.
I think the alternative would be to find the plug in the right front corner and run the wires exposed under the cab if necessary.
thanx
thanx
Meridian_Mike
27
01-21-2019 07:03 AM
Moose F150 4x4
12-31-2004 11:56 AM
