Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 6.2L V8
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8 SPONSORED BY:
  #1 (permalink)
Old 10-21-2012, 12:03 PM
Dave HM Dave HM is offline
Garage is empty, add now
Dave HM is starting off with a positive reputation.
Running wires under carpet? 2012 F 250
I want to run a couple of wires from the Upfitter Switches to the left front underside of the bed. I understand that there are rubber plugs in the front and rear of the lower corners of the crew cab.
I would like to run the wires along the side under the carpet from front to rear. So how does one remove the inside moldings to be able to get wires under the carpet?
Hopefuly someone here has conquered that challenge and is willing to share.
I think the alternative would be to find the plug in the right front corner and run the wires exposed under the cab if necessary.
thanx
  #2 (permalink)
Old 10-21-2012, 02:39 PM
guy I knew showed me how to yank straight up and they pop off.
was able to fish the wires through the rest of the paneled areas and out the rubber plug in the back.
  #3 (permalink)
Old 10-22-2012, 02:10 PM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2011 Ford F-350
2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all
Post back up if you have any other questions about running wires. I still have a pretty good idea of all the nooks and cranny's you can get wire into from my stereo project.
Click the image to open in full size.
__________________
Matt
2011 F350 - 6.2 CC, LB, 4.30s, Lariat Ultimate pkg, FX4, Amp steps, Lockpick, AC LC6i, JL HD900/5, JL 13TW5, JL C5-570's, Bilstein 7100 stabilizer, Rancho RS9000XL's, Leveled w/ 35" Toyo M/T's and 5 Star tuned
**Sold - 2000 F250 V10, 6.5" Pro Comp, 37" Toyo MT's
  #4 (permalink)
Old 10-30-2012, 08:24 PM
Adventure Rider's Avatar
Adventure Rider Adventure Rider is offline
Adventure Rider is gaining momentum as a positive member of FTE.
I don't know if you are planning to do this but it is good practice to run along other wire harnesses to keep clean and neat and at the point of exit from the cab it would be good to encase the wires to prevent chaffing
__________________
2012 F250 SD 6.7PSD 4x4 CC XLT 3.55 ELD FX4 Tuxedo Black, Line-X Liner, Ford Molded Mud Flaps and wheel liners, Weather Tech Floor Mats
Current Bikes 2011 R1200 GS Adventure Smoke Grey Metallic Matt - Trans-Lab Slayer
2009 G450X White - Serious woods weapon
IBA #35651
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
