Stall/ruff idle/skip - Ford Truck Enthusiasts Forums
Old 10-21-2012, 11:51 AM
MucksCo MucksCo is offline
MucksCo is starting off with a positive reputation.
Hey, 04 6.0 running down the pike, water in fuel light came on then it appeared to shut down to an idle then stalled, will idle for 45 seconds then stall. Only throwing cyl 7 balence code.
Old 10-21-2012, 11:53 AM
It's dead on the road, I'm waiting for a tow rig
Old 10-21-2012, 11:57 AM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
What fuel filters are you using?
When was the last time you changed them?
Did you drain the water (remove the plug on the HFCM) when you last changed the filters?
Any recent work done?
How low is your fuel level?
I would get the batteries load tested as the first step. Then I would check FICM voltages (KOEO, cranking, and at 2000 rpms if you can get it started). If you have a scan tool, there are a lot of readings that will help troubleshoot (FICM sync is the first one I would look for).
Old 10-21-2012, 01:19 PM
I have a snap on Solas so once I get it home ill check that
Old 10-21-2012, 01:20 PM
I use the motorcraft filters. The battery's are under a month old
Old 10-21-2012, 08:08 PM
Battery's a month ago along with an altinator, new FICM and 3 injectors 3 weeks ago along with a full service.
New carb fade to stall at 750 rpm reamer 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 14 04-11-2015 09:56 PM
460 Idle rough and almost stalls when put in gear daddylee100 1987 - 1996 F150 & Larger F-Series Trucks 5 03-02-2014 09:40 PM
misses when driving and under load, idle stalls gbrewer 1987 - 1996 F150 & Larger F-Series Trucks 1 07-10-2013 02:45 AM
2000 explorer stalling in cold weather roree Explorer, Sport Trac, Mountaineer & Aviator 4 01-07-2010 01:49 PM
300 I-6 1 Barrel Carb Idle Question PaulzF150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 12-07-2009 05:19 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
