New Guy 5.0 - Ford Truck Enthusiasts Forums
5.0L Coyote 5.0l Ford OHC Coyote engine for 2011+
New Guy 5.0
Old 10-21-2012, 08:50 AM
heston75 heston75 is offline
heston75 is starting off with a positive reputation.
New Guy 5.0
Hello all, I'm a proud new F-150 owner! Yes this is also my first post. I had a question for those with the experience. I just bought a 2012 xlt 4x4 with the 5.0. I've been following this site for some time and noticed there doesn't seem to be many posts on problems with this motor. This was one major reason I chose it over the eco. I don't tow heavy and reliability is #1 with me. That being said is there anything I should keep an eye on with these motors?
This is by far the nicest truck I've ever owned. My last F-150 was a 94 with the 5.0, never had any trouble with it either but man was it a dog! My last 3 vehicles were Rangers, gone but not forgotten. Thanks for your input, this site is a great place for info! I'm sure I will learn alot being here. Thanks again!
Old 10-21-2012, 04:42 PM
smokersteve's Avatar
smokersteve smokersteve is offline
smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.
Watch for leaks.
Stay on top of your oil changes.
Especially at the 0-20,000 miles because it is braking in through out that period.
And use only motorcraft filters
I get mine from ROCK AUTO.
Old 10-21-2012, 04:58 PM
Thanks for the tips. I will keep an eye on it. Is there anyplace it seems prone to leak or was this just in general? I only have about 700 miles on the motor but was thinking I would change it at 1000 and then go to normal schedule.
Old 10-21-2012, 09:03 PM
Yes just general leaks.
This is my plan.
I got some chevron 5w20 on sale for $2. I got enough to change the oil every 3,000 miles untill I get to ~15,000 miles. Then I will go 7,500 miles on 0w20 on mobil 1.
Old 10-22-2012, 11:38 AM
There is a good mod to do for the 5.0L, and any other engine.
Install an oil catch can. It mounts on to the crank case vent tubes. Do a f-150 5.0L Catch Can" search on google. there will be a few threads with lots of pictures.
You can buy a kit or make your own. They are easy to make. I am planning on making one.
Old 10-22-2012, 02:45 PM
ChargersFanInCO ChargersFanInCO is offline
ChargersFanInCO has a good reputation on FTE.ChargersFanInCO has a good reputation on FTE.ChargersFanInCO has a good reputation on FTE.
Mine hasn't dripped a drop of anything, but it's only a few months old. I love it.
Old 10-22-2012, 02:54 PM
It is not for driping oil. It is for blow by from the crank case vent system allowing engine oil to get in to the intake. The oil will burn from the combustion leaving carbon in the combustion chamber.
Old 10-29-2012, 02:43 PM
Quote:
Ahhhh...I KNEW there had to be some flaw with this otherwise wonderful engine...I'll look into it!
New (to me) 2013 STX with the 5.0 Engine dickiefrank 2009 - 2014 F150 6 01-05-2017 08:11 AM
HELP NEEDED... 5.0 F150 '89 MISFIRE, BOGS, POSSIBLE "DIESELING" TennesseeKid5.0 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 11-23-2016 12:45 AM
1991 Tbird 5.0 HO into 1989 F150 reddirtfalconer Engine Swaps 1 08-31-2016 12:27 PM
Howdy! JAZ8602 1987 - 1996 F150 & Larger F-Series Trucks 3 08-30-2016 08:20 AM
302?? Bashbro60 1987 - 1996 F150 & Larger F-Series Trucks 12 12-17-2015 08:37 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
