2002 F150 Noise on start up
I have a 2002 crewcab with a 5.4L with 160K and it has started to make a noise on start up only. The noise lasts for less than a second and is then quite and it runs perfect. I use Valvoline Max-Life 5W20 oil and a Motorcraft filter. Sounds like a lifter tap until the oil get to the top of the engine?? Sounds like rattle maybe. Only happens at startup, or after it sits for a while. I know these have issues with the spark plugs its not that as I have recently changed them and the issue is the same..
Any help would be appreciated!!
Thanks!!
Thanks!!
I just bought mine, but it sounds like they all do it to some extent. Running an engine for 1-3 seconds dry really wont hurt anything because the oil that does stick to those parts will lube it until the oil pump can get everything going. And, btw, these trucks are OHV which means no lifters and no pushrods.
my '98 5.4 has always done this since i bought it with 63k..now have 86k and no change. i have tried different weights of oil no change. i always use motorcraft filters.
i have decided its just normal and dont worry about it. i remote start the truck before going anywhere so i dont have to listen to it anymore either haha
Oh that noise
Started to hear it occasionally on start up couple years ago, rattle almost a ping. Back in May it started to get worse finally becoming a full fledged KNOCK in August. Pulled the oil pan and discovered #7 & #8 Rod Bearings Burnt and Worn from Oil Starvation (208,000km.).
$ 2500.00 Later I now have a 5.4 with 96K on it and a years warranty on Engine and Labor. Happy to discover the New 5.4 just did 21 MPG Imperial 17+MPG US on a Tank with Town Highway Driving. Now if I can keep the Rocker Panels and Pan Rails from Rusting Out. Added Bonus was when I left it at the Dealer for new Tank Straps the Tank Began to Leak, got a new Tank from Ford. Not so great is now the AC Compressor Bearing is shot......Can't wait to see what November has waiting.
