ranger 2.5L timing belt replacement - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 05-19-2003, 08:42 PM
chiefguns chiefguns is offline
chiefguns is starting off with a positive reputation.
does anyone out there know what ford recommends about the mileage interval for changing the timing belt on a 99 Ranger with the four cyl 2.5L engine? Thanks
Old 05-19-2003, 08:46 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
Welcome to FTE!!!
I believe its around 60k miles but check your owners manual to make sure.
Old 05-20-2003, 08:50 AM
Rancha9's Avatar
Rancha9 Rancha9 is offline
Rancha9 is starting off with a positive reputation.
60K? If the timing belts on the 99's and 2000's are the same then it's 110K. I'd check it before then, though, just to make sure. Definately don't want that thing breaking... They tend to leave a mess.
Old 05-20-2003, 08:57 AM
Bob Ayers Bob Ayers is offline
Bob Ayers has a good reputation on FTE.Bob Ayers has a good reputation on FTE.Bob Ayers has a good reputation on FTE.
Quote:
The 4 cylinder in the Ranger is a "non interference" engine, meaning it won't bend valves if the timing belt breaks....The
worst that will happen is it leaves you stranded.......
Old 05-20-2003, 09:07 AM
Rancha9's Avatar
That's always nice to know... Guess I'm too used to the older motors still...
Doing a timing belt on a 93, need lots of advice 1998Ranger25L153CID Ranger & B-Series 2 06-12-2014 07:50 AM
1995 ford ranger fearfactory 4 Cylinder Engines 4 03-22-2009 07:15 PM
86 2.3L ranger timing belt replacement help 59dumper Ranger & B-Series 6 11-25-2008 08:40 AM
Timing Belt Tool big catfish Ranger & B-Series 2 01-31-2006 09:23 PM
Timing chain (belt)? StangVT66 Ranger & B-Series 2 01-21-2003 12:19 PM
Tags
1999, 2000, 25, 25l, 99, belt, changing, diagram, engine, ford, interval, ranger, replacement, timing, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
