347 vs 408 vs 427 EFI strokers - Ford Truck Enthusiasts Forums
Old 10-21-2012, 12:18 AM
FossenRacing's Avatar
FossenRacing FossenRacing is offline
FossenRacing is starting off with a positive reputation.
What is the best efi stroker.
Have heard the 408 is very reliable and parts are readily asseable.
heard 427 is hard to the find parts
going into a 92 f150 that had a 5.0l
Who has done a EFI stroker please cut in
Old 10-21-2012, 12:55 AM
craveman85 craveman85 is offline
craveman85 is starting off with a positive reputation.
you should be able to find everything you need from summit racing. im sure there are plenty of parts for the 427 out there. you might actually find the parts to build the bigger engines will cost about the same as the smaller ones. i vote 427 because i had a cool idea once for a "cobra" f150 that i thought would be really cool.
Old 10-21-2012, 01:07 AM
Quote:
I kinda already have a cobra f150.
My 77 f150 4x4 has a 500 hp 390 fe.
Did a quarter mile in 14.6 sec. And that was with a messed distributor we had to advance Big time to run. Mashed a few 5.0l mustangs.
Will have better times next time we race at the air port.
And will have a stroker NITE edition 92.
Haven't decided between a factory EFI, aftermarket EFI, or carb.
Now a 427sohc would be irate in a 9th gen f150.
Old 10-21-2012, 01:08 AM
Evan_P's Avatar
Evan_P Evan_P is offline
Evan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to behold
The 347 is a stroker of the 302W. The 393 and 408 are strokers of the 351W. The 427 is a Ford Racing crate engine that uses a 351 Boss block. If you want real power, get a used 351 with as little miles and issues as you can, tear it down, have it machined and then make it a 393 or a 408.
Old 10-21-2012, 01:28 AM
Quote:
Want to do the 408 and finding a 351w roller block is fairly simple. I have a great machine shop that gives me a discount.
The EFI is the grey area. I know the basics but not sure what all needs to be done in the electrical department.
I know MAF is the way to go. I know the ecu needs to be programmed to the parameters of the crank cam and whatever else.
Probably going for aluminum heads, hi flow intake, aggressive cam, big MAF , msd ign. Headers.
Old 10-21-2012, 09:21 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
I'd have to vote 408 here too considering this is going in a heavy truck, the only way a 347 would be comparable is if it gets a blower. If you want to keep EFI you'll be replacing or upgrading everything EFI and fuel system related from the fuel pumps to the injectors and fuel rails the intake manifold and the computer and portions of the wiring harness. But with that done and a tuner module attached to the computer you can dial it in from the drivers seat on a laptop.
Old 10-21-2012, 02:52 PM
just buy a mid 90's 351 powered truck. you should be able to get one fairly cheap and have all the electronics including maf. then just part out/junk the rest. ive seen a few 351 f150's in my area for 5-800 bucks that had good motors and trannies in them.
Old 10-21-2012, 03:27 PM
Boss08v10's Avatar
Boss08v10 Boss08v10 is offline
Boss08v10 is a splendid one to beholdBoss08v10 is a splendid one to beholdBoss08v10 is a splendid one to beholdBoss08v10 is a splendid one to beholdBoss08v10 is a splendid one to beholdBoss08v10 is a splendid one to beholdBoss08v10 is a splendid one to behold
FordStrokers.com 331-347-408-418-427 Custom Built Small Block Ford Engines
Oh yeah my 5.0 mustang, stock motor except for cam and other bolt ons run's low 12's.
Old 10-21-2012, 08:09 PM
UNTAMND's Avatar
UNTAMND UNTAMND is online now
UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.
Are you going to run overdrive or not.
Your best bet is to upgrade to mustang maf setup and ecu for the tuning support if you're going to use a c6 and not going to use an e40d.
If you want overdrive I'd use an explorer efi setup and get a built 4r70.
90mm maf
60lb injectors
Trickflow intake or edelbrock victor intake
1/2" fuel rails and aeromotive regulator
255hp pumps minimum or the Bosch 044 pumps at 310 (or new walbro 400 pump)
Build it with under 9.5 compression so you can boost it later.
That's a great start, but you'll need a lot more.
Make sure you find a good tuner, and ask which ecu they can and have experiance with tuning and get back to us with what they say. That will be a big consideration as well.
You can use tweecer or megasquirt or quarterhorse but usually you're on your own with the learning curve and tuning. We can help with that also.
Old 10-22-2012, 01:35 PM
I was talking bone stock mustangs. One was my brothers 95 5.0l No bolt ons.
I only had a cam intake headers and carb.
Every thing else was stock.
Pretty impressive for a 4x4 that's twice the weight.
This truck will go through a 200 foot long mud pit that's 2.5 feet deep in 4.4 to 7.6 seconds. Love to see that stang try that.
Lol. I'm just playin. Your stang sounds baddass.
Old 10-22-2012, 02:53 PM
Freightrain's Avatar
Freightrain Freightrain is offline
Shiftoholic
Freightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to behold
If you plan on building it and running it hard, then don't try using a stock 302 block. You'll split it open like a pineapple(seen in first hand).
If you have to buy an aftermarket block, you might as well go BIG. They make 427ci Windsors(351). Friend has one, very mild, pump gas, roller cam and makes 500+hp. Runs it in a shortbed dent side that goes 12.5's at the track on street tires and AOD.
As for EFI? What makes the difference which stroker? Friend runs 360ci (302 Dart block) with '89 Mustang computer and Motorsport extender. Goes 10.6's.
427 stroker Brandy4ever 1987 - 1996 F150 & Larger F-Series Trucks 25 12-13-2016 11:17 PM
7.3 PSD vs 408w Fordman96 Engine Swaps 3 08-21-2013 09:00 PM
351w stroker motor wquestions 1990f150kid Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 10 03-22-2012 08:57 PM
H.P. Gains from 408 Stroker Kit and other mods? chevyassasin Performance & General Engine Building 4 10-10-2011 04:23 PM
351w Stroker or 460 (towing) BKB Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 05-31-2006 10:57 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
