Desperately need help assembling my mustang 2
I've installed a few MII kits. They are all just about the same. Question, are you checking these clearances with the truck jacked up, and no load on the front suspension? If so, quit worrying about it as the entire thing will settle a bunch when weighted. You have a cross member, it is likely made of 2x3, or 2x4 rectangular steel tube, likely 1/8, or 3/16 wall. You have a lower control arm, and it's wider than the cross member. There is a spacer tube welded to the cross member where the lower arm goes. There is a short spacer on the lower ball joint. Use it. The rack boot will rub the lower arm if the truck is jacked up, and by your description, you are no where near needing to worry about it. There should be a pair of washers on the lower a-arm bolt. One at the bolt head, and one at the nut. They are likely 1/16" thick each, which would take up half your gap. Tightening will close the rest. You cannot tell any thing about clearances until it's tightened up, and has loaded weight on it. The springs will look too tall, they're not. The tie rod ends will pivot upward, leaving approx 1/4-1/2" of clearance when loaded down. They say don't use lock tight. If you do, use the blue, and not the red. The major bolts use nylock nuts.
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
12-24-2006 01:49 PM
