69, ive never delt with points before either, am going to switch to HEI from CRT as soon as i can but still have to drive it til then $ been REAL tight latley. Do i need to reset my points when i time it as well
Sux azz going from 70,000 a year back down to 25 or 30 and having to rebuy every tool ( and everything else) that i bought over the last 20 yrs
First set points like at .017 then do timing at 6* BTDC. Spark Plugs .034 Aw yes eating crow is really like a kick in the nuts feeling having to stating over. Kind of like going through a divorce.......orich
EXACTLY like going thru a divorce how did you know? Lol
I've been told that you can/should run closer to 18* before TDC. Any advantage/disadvantage?
All depends where you live and if your like a flat lander or in dry hot deserts to the mountains. But if your ever going to be doing any towing go with the stock setting...Oh and octane oh gas you use..orich
Ok knew their was a difference with the 1968 & 69 trucks models but had to look it up. Book says if you have the Exhaust emission control Points set at .021 Or dwell 24-29.The stock Engine. compression is 140 psi. Sorry for the delay but I'm old and slow moving NOW..orich
I use 10-12* on stock stuff. Give a touch of UMPH without making it knock/ping itself to death. Lets you run lower grade fuel.
Points around .020 or 28-32 on a dwell meter. You must reset timing if you mess points. On the other hand if you reset timing, you don't need to mess with points.
Points mess with timing, but timing does not mess with points.
