new oil pan on/rust in fuel filter - Ford Truck Enthusiasts Forums
Old 10-20-2012, 11:02 AM
emd160 emd160 is offline
emd160 is starting off with a positive reputation.
Well I finally had time to change out my composite oil pan to the metal one. Nothing was wrong with the old one but Ive seen the composite pans get hit by a rock and crack so I decide to get the metal one. It didnt take long once I had the oil drained and its very easy to get to. Once i had the old pan off I did find two piece of sludge stuck to the oil pickup screen, they had a sliver of aluminum in them. My oil repots have been coming back with high aluminum content so Im not reallly sure what to think being my motor had 33k miles on it now. I also changed out the fuel filter and when I dropped the frame mounted filter I found about a teaspoon of rust in it. I'm not one to run my truck down to E but I admit I did so twice since the last filter change. Since I found the fuel filter kit for 60 buck(ford dealer wanted $140) I think I will move my fuel filter changes to 10k miles instead of 15k. Last but not least I also added SPE 6.7 Full Lock Diff Kit which allows the locked rear end to stay engaged past 20 mph. It was a simple 10 min installation with just a few wires and easy directions to follow
New oil pan
composite pan
old pan off and view of oil pickup
two pieces of sludge that came off oil pickup screen
new pan on
Rust in the bottom
Old 10-20-2012, 12:30 PM
biz4two's Avatar
biz4two biz4two is offline
biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.
Thumbs up
GREAT report!
Never heard of the full lock diff kit before. Very interesting...
biz
Old 10-20-2012, 12:34 PM
Troy Buenger's Avatar
Troy Buenger Troy Buenger is offline
Troy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to behold
Nice report emd160....
You may want to consider purchasing from another diesel supplier or do you fill from an external storage tank?
Also do you drain you water seperator/fuel filter monthly?
Old 10-20-2012, 12:57 PM
Powerdude Powerdude is offline
Powerdude is gaining momentum as a positive member of FTE.
33k miles and your fuel system is rusting already?
So when the fuel pump implodes and sends shavings throughout the system, guess we already know it will be a warranty denial based on rust in the fuel system.
Well, at least you know what's going to happen. That can bring peace of mind.
Old 10-20-2012, 02:33 PM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Quote:
Huh...troll much?
I'm no technician, but I doubt this means anything. The procedure to check for contamination involves pulling two valves from the HPFP and checking for rust on them.
Old 10-21-2012, 05:46 PM
Troy- yes I am going to switch my fueling location and i might even drop the tank here this winter and clean it out. I drain water seperater once every two weeks at least(every other fill up) and have never seen any water in the fuel drained.
powerdude- i really dont see it as my fuel system is rusting away more like I picked up rust somewhere when i filled up and it got sucked into the fuel system that far when i ran it low on fuel
My biggest concern is where to get fuel now at there only two places close by and there still 15 mintue drives and also why the high aluminum readings in my oil excpesially after seeing that shaving
Old 10-21-2012, 08:19 PM
emd160,
You never seen any rust when you drained your water seperator? Eitherway another fuel supplier would be on top of my list.
Also what brand of oil and weight do you use?
Old 11-03-2012, 09:09 AM
bridge's Avatar
bridge bridge is offline
bridge has a great reputation on FTE.bridge has a great reputation on FTE.bridge has a great reputation on FTE.bridge has a great reputation on FTE.bridge has a great reputation on FTE.
Question: where did you get the oil pan and did it come with new bolts?
Old 11-03-2012, 10:02 AM
rickatic rickatic is offline
rickatic has a great reputation on FTE.rickatic has a great reputation on FTE.rickatic has a great reputation on FTE.rickatic has a great reputation on FTE.
Quote:
Originally Posted by Crazy001 View Post
Huh...troll much?
Rust evidence anywhere in the system will result in a warranty denial...at least at Ford...the proof can be found in my shameful experience. The rust that Ford used to deny warranty coverage was on a segment of the solenoid that see's "NO" fuel flow or exposure as it is outside of the pump...
Regards
Old 11-03-2012, 11:13 AM
bridge's Avatar
If you switch from composite to steel you will also need the following bolts (which my parts guys didn't order, even though the succession note in the computer says to order it): w714962s437
Old 11-03-2012, 03:07 PM
Quote:
Regards
So which was it.... Water or Rust that caused the warrenty denial?
Old 11-03-2012, 03:40 PM
biz4two's Avatar
Arrow
Quote:
Try here...it has a complete setup!
Spe 6 7 Steel Oil Pan Upgrade Kit - Spe67opuk - Engines and Components - Ford 6 7L 11-12 - by Spe
biz
Old 11-03-2012, 03:59 PM
bridge's Avatar
Quote:
Originally Posted by biz4two View Post
I was checking that out, and its about $40 more than what the dealer charges. $27 for the pan and $14 for the bolts at the dealer counter.
thank god for superdutys emd160 6.7L Power Stroke Diesel 38 02-19-2012 07:00 PM
new pics of truck emd160 6.7L Power Stroke Diesel 18 07-15-2011 08:03 PM
Did some hauling this weekend emd160 6.7L Power Stroke Diesel 10 07-05-2011 09:58 PM
Changed spark plugs 5.4 3V @ 52k miles - pics D-Rock 2004 - 2008 F150 8 03-29-2011 07:55 PM
newbie pics silver&green94 Aerostar 13 02-08-2009 03:01 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
