How do I get better mpg for my 79 f150 302 - Ford Truck Enthusiasts Forums
Old 10-20-2012, 10:24 AM
Valdez352 Valdez352 is offline
Valdez352 is starting off with a positive reputation.
I have a 79 f150 with a stock 302 I get 8-9 mpg what can I do to get better mpg what upgrades?.
Old 10-20-2012, 11:01 AM
jim collins jim collins is offline
jim collins has a good reputation on FTE.jim collins has a good reputation on FTE.jim collins has a good reputation on FTE.
It depends some on how you drive it and what it's used for. What transmission and rear gear ratio. I get between 12 to 14 with my 73 F-100 , 2 wheel drive. It's got the 302 , 2bl carb ,3 speed transmission and rear gears are 3:25. You having a F -150 , a lot of them had 3:50 rear gears if they a 2 wheel drive. You should get about the same as i get i believe. If it's a 4x4 then i don't know. I should be getting better than what i do.
Old 10-20-2012, 11:21 AM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
2x... a rear gear of 2.80 or 3.00 will stretch the MPGs. That and a well tuned engine and the driving habits of a nun.
Old 10-20-2012, 11:57 AM
garthneddy's Avatar
garthneddy garthneddy is offline
garthneddy is gaining momentum as a positive member of FTE.
I routinely get 14.5 mpg with mixed driving. That's coming from an 81 4x4 f250 with the 302, zf5 and 4:10s. Sounds to me like you just need to get your 302 properly tuned.
Old 10-20-2012, 12:01 PM
customrich&matt's Avatar
customrich&matt customrich&matt is offline
customrich&matt is starting off with a positive reputation.
dont drive it
lol
Old 10-20-2012, 06:46 PM
dakotarider's Avatar
dakotarider dakotarider is offline
dakotarider is gaining momentum as a positive member of FTE.
Fuel mileage
With my 75 F-100 w/ 360, my pops use to say it got 8-10 gallons per mile whe he had it! And it would pass everything but a gas station!
Old 10-21-2012, 05:51 PM
If I put 3.00 gears in the rear what gears should I put in the front to balance it out my f150 is 4wd with 6 inch lift and 36's
Old 10-21-2012, 06:48 PM
nine inch rear nine inch rear is offline
nine inch rear is starting off with a positive reputation.
Quote:
You need to put the same ratio in front and back. 3.00 gears with 36 inch tires and a 302? Honestly, with that combo your truck wont be able to get out of its own way. If you want your mpg to come up, you need to dump the rotating mass of those tires. Maybe 32/33 inch tires, but with a 6 inch lift you might not like the stance of the truck. Another thing to keep in mind theres no aerodynamic qualities on our rigs. They are what they are. My combo is 351M with 33 tires and 353 gears. I get 8 around town, and 12 on the highway if I keep it about 60
Old 10-21-2012, 11:31 PM
fordcrzymike's Avatar
fordcrzymike fordcrzymike is offline
fordcrzymike is gaining momentum as a positive member of FTE.fordcrzymike is gaining momentum as a positive member of FTE.
That might have been good to mention in the original description of your truck... No wonder your getting poor mileage, your running 36s. Your driving a lifted truck from the 70s with over size tires, your going to get terrible mileage no matter what you do. With 36s you might be better off going with a lower gear ratio so the engine doesn't have to work so hard. 4:56s would probably be your best bet, you could probably get by with 4:10s. I don't know what your ratio is right now.
Old 10-21-2012, 11:49 PM
mike240zt's Avatar
mike240zt mike240zt is offline
mike240zt is starting off with a positive reputation.
ya you probably have 3:50 stock and 36's are to much. 33's are about max with that kind of gearing. 4:10's would be much better for 36's
Old 10-22-2012, 04:50 PM
Ok so 4:10 would be the best gear ratio for the lift and tires what about a new cam what do you think the best to buy would be?
Old 10-22-2012, 05:35 PM
SuperDuty93's Avatar
SuperDuty93 SuperDuty93 is offline
SuperDuty93 has a good reputation on FTE.SuperDuty93 has a good reputation on FTE.
Check these out, i have their level 3 in my 390, sounds great and hauls butt
Search results for: 'ford'
Id recomend
1st)
Ford Hydraulic Flat Tappet Camshaft
2nd)
1979 F150 300 6 fuel economy Ford_Guy123 1973 - 1979 F-100 & Larger F-Series Trucks 5 04-15-2016 03:46 PM
Mpg? Truck Guy99 1987 - 1996 F150 & Larger F-Series Trucks 29 05-08-2014 11:09 AM
what your option? 351w to 302? Super Econoline 1973 - 1979 F-100 & Larger F-Series Trucks 18 10-04-2012 10:41 PM
1985 f150 6 cylinder 302 shawnfrompa94 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 12-25-2010 08:59 PM
What mpg you get out bronco and list what you did to get good mpg Milwaukee1979F150 1978 - 1996 Big Bronco 29 09-30-2009 03:14 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
