Straight axle swap - Ford Truck Enthusiasts Forums
Straight axle swap
Old 10-19-2012, 10:41 PM
f1506cyl f1506cyl is offline
f1506cyl is starting off with a positive reputation.
Straight axle swap
I have a 88 f-150 that already has a 1/2 ton dana 44, what I'm wanting to know is; if I go higher can I use the drop radius arm brackets from a 79 kit or do I have to custom make brackets? Also can I convert the 1/2 ton dana 44 to 3/4 by changing the internals and spindles or would it just be easier to convert everything to leaf spring?
Old 10-19-2012, 11:14 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Welcome to the forum. use the search feature This has been covered TONS
Dana 44 hp interchange with dana 44 hd 8lug? BIGS003 1973 - 1979 F-100 & Larger F-Series Trucks 16 05-21-2013 09:19 AM
1/2 ton to 3/4 ton stromburg 1973 - 1979 F-100 & Larger F-Series Trucks 1 10-17-2012 11:33 AM
Can an open knuckle coil spring 1/2 ton dana 44 be converted to 3/4 ton leaf sprung?? goda123 Offroad & 4x4 2 03-05-2010 07:28 PM
dana 44 3/4 ton knuckles on 1/2 ton axle fords_forlife Offroad & 4x4 1 06-30-2006 04:34 PM
TTB Upgrade Questions Ed Trethewey Offroad & 4x4 3 11-08-1999 05:40 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
