352 rods in a 390?
352 rods in a 390?
What would happen to the motor if I used 352 rods with 390 crank?
Now the back story!!! I'm a votech collage student and I recently made a mistake with identifying the motor I was taking apart. I mistakenly thought that they only put 390's in cars. Well I got it all torn apart and parts ordered for a 390 when I found out that t is a 352. I was talking with my dad about what to do and he said that he might have a crank for a 390 and I can get the block bored to the right size what would happen if I used the 352 rods on the 390 crank and pistons?
Well I was told, by my uncle, that it was a 390 when i pulled it out of the crashed Custom 500. I took it apart and sent the block to a local guy to clean it because the school's cleaner is not very good. I knew there was going to be some ring ridge so he just stuck an internal mic in it and thats how I got the news that it is a 352 not a 390.
you probably have a 390 as the bore is the same only stroke is different .
you can check your crank 390 has a stamping # see link for breakdown
Ford FE Crankshaft Casting Numbers - FORDification.com
Stock deck for a FE motor is 10.17 inches.
So, 1/2 the stroke, + the rod, + the compression height of the piston can't add up to more than 10.17.
Diagram here:
Forum Faqs
FE info, excluding for the most part the 360, the older Edsel and later PU 390s:
Kelly hotrod - Ford Engines Page 1
Ford 352, 390, 406, 427 and 428 Engine Blocks
FE Series Engine Specification Chart
Once you confirm what you have, a direction can be chosen.
Diagram here:
Forum Faqs
65'f1004x4conver
12-07-2006 08:39 PM
Brian 352
05-10-2005 04:58 PM
jazzy66
09-21-2004 09:48 AM
