oil recommendation for y-block - Ford Truck Enthusiasts Forums
Old 10-19-2012, 06:55 PM
54effy 54effy is offline
54effy is starting off with a positive reputation.
I was wondering what oil I should use in a 292 Y-block. I thought Rotella was the suggested oil on a previous post but I may be wrong.
Old 10-19-2012, 08:51 PM
ibuzzard's Avatar
ibuzzard ibuzzard is offline
Gone But Not Forgotten
ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.
If your engine still has the stock unhardened valve seats,the idea is to use an oil with as high a level of ZDDP,which has been decreasing, to lubricate the valves. Google it, you'll get no end of articles.
If you have hardened valve seats,just use a good quality oil.
Old 10-19-2012, 09:46 PM
Thanks. I'll try that.
Old 10-19-2012, 09:51 PM
raytasch's Avatar
raytasch raytasch is online now
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
The high ZDDP will lubricate the cam and lifters, benefiting that area. Really don't think oil should be in the area of the valve seats. I am running Brad Penn.
Old 10-19-2012, 09:57 PM
jhaas63 jhaas63 is offline
jhaas63 is gaining momentum as a positive member of FTE.
Joe Gibbs racing oil. It is expensive but so are engine rebuilds. Amazon . com
About 10 bucks a quart.
Old 10-19-2012, 10:00 PM
ibuzzard's Avatar
Quote:
Duh, I am confusing two separate issues. Tim Mcmaster did recommend I use Brad penn oil when he built my current Y,which I do use but have to special order it. I was worried about using a lead substitute for the valves, but he installed heads with the hardened seats, so it's a non-issue now. I was ready to install the NOS oiler kit I had bought,which he said is not necessary with modern detergent oils and the common mod used to correct poor oiling problems.Sorry about the bad info, I'm easily confused.
Zinc Additive in my 352's oil? 64F-100 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 2 10-12-2010 10:15 PM
Y-block distributor pcmenten Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 18 02-08-2006 01:06 PM
Flat tappet cams, oil and zddp 46yblock Oil & Lubrication 14 10-16-2005 04:36 PM
Anybody have a sound file of a y-block idling? chipmunck Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 15 04-19-2005 08:20 PM
Y-block Gaskets Kenny Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 4 08-08-2001 07:03 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
