302 idle problems
Old 10-19-2012, 04:54 PM
ItsAFord55's Avatar
ItsAFord55
ItsAFord55 is offline
302 idle problems
i did a tune up on my 1991 f150 acouple weeks back and sinse i did it it started having a rough idle but it drives perfect. just when you are idling it has a stutter to it. It also likes to go to high idle even after youv been driving it the same day.
Old 10-19-2012, 06:30 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,164 Likes on 919 Posts
Please give us details of this "tune-up" you refer to.
Old 10-19-2012, 07:19 PM
ItsAFord55's Avatar
ItsAFord55
plugs,cap,rotor,wires,and fuel filter.....iv double checked the firing order
Old 10-19-2012, 07:22 PM
Turxx's Avatar
Turxx
Turxx is offline
fix your vacuum leak
Old 10-19-2012, 07:57 PM
rla2005's Avatar
rla2005
Did you correctly route the plug wires?
courtesy of Steve83
Old 10-19-2012, 07:59 PM
rla2005's Avatar
rla2005
That is a valid statement as well. Did you have a high idle before?
Old 10-19-2012, 11:46 PM
ItsAFord55's Avatar
ItsAFord55
yes it had the high idle before too but its only when you first start it up. it could just be going up to high idle but its weird tht it does it every time.
Old 10-20-2012, 09:35 AM
rla2005's Avatar
rla2005
Verify your plug wire routing, check for codes by running the KOEO tests and CM check.
gbrewer
01-27-2015 06:40 PM
captain1997
09-24-2011 05:44 PM
djx4yz
02-06-2007 01:11 PM
mark alderson
09-02-2005 09:17 AM
Troll
09-27-2004 07:04 PM
Quick Reply: 302 idle problems
