302 idle problems - Ford Truck Enthusiasts Forums
302 idle problems
Old 10-19-2012, 05:54 PM
ItsAFord55's Avatar
ItsAFord55 ItsAFord55 is offline
ItsAFord55 is starting off with a positive reputation.
302 idle problems
i did a tune up on my 1991 f150 acouple weeks back and sinse i did it it started having a rough idle but it drives perfect. just when you are idling it has a stutter to it. It also likes to go to high idle even after youv been driving it the same day.
Old 10-19-2012, 07:30 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Please give us details of this "tune-up" you refer to.
Old 10-19-2012, 08:19 PM
ItsAFord55's Avatar
plugs,cap,rotor,wires,and fuel filter.....iv double checked the firing order
Old 10-19-2012, 08:22 PM
Turxx Turxx is offline
Turxx is starting off with a positive reputation.
fix your vacuum leak
Old 10-19-2012, 08:57 PM
rla2005's Avatar
Quote:
Did you correctly route the plug wires?
courtesy of Steve83
Old 10-19-2012, 08:59 PM
rla2005's Avatar
Quote:
That is a valid statement as well. Did you have a high idle before?
Old 10-20-2012, 12:46 AM
ItsAFord55's Avatar
yes it had the high idle before too but its only when you first start it up. it could just be going up to high idle but its weird tht it does it every time.
Old 10-20-2012, 10:35 AM
rla2005's Avatar
Verify your plug wire routing, check for codes by running the KOEO tests and CM check.
92 460 low idle in gear daddylee100 1987 - 1996 F150 & Larger F-Series Trucks 8 10-02-2015 01:48 PM
slight rpm flutter at idle jdm5630 6.4L Power Stroke Diesel 4 03-03-2015 10:39 AM
03 6.0 rough idle issue af11 1999 to 2016 Super Duty 2 04-20-2014 11:38 PM
High idle Iaff113 6.0L Power Stroke Diesel 11 03-03-2014 12:20 PM
High Idle when shifted into Drive? allingeneral 6.0L Power Stroke Diesel 21 02-16-2014 08:54 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
