Reverse lights don't work on 71 f100 400 v8 - Ford Truck Enthusiasts Forums
Old 10-19-2012, 05:04 PM
Stang Thang Stang Thang is offline
Stang Thang is starting off with a positive reputation.
my reverse lights don't work my 71 f100 400 v8. I have seen posts where ppl have problems with reverse lights and starting their truck in neutral, I am able to start in neutral but don't get any thing when in reverse. I am handy with electrical work, can someone tell me where the reverse electrical wire first gets contact. I am going to rewire it myself but I don't know where to start searching.
Old 10-19-2012, 05:29 PM
RichS2659 RichS2659 is offline
RichS2659 is starting off with a positive reputation.
Important to know: auto, 3 speed, or 4 speed?
Old 10-19-2012, 05:39 PM
Quote:
Im pretty sure that is a four speed
Old 10-19-2012, 05:49 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
4 speed manual transmission: The backup lamp switch threads into the shift tower.
With a 4 speed, you can start in any gear...which makes me wonder if you really have a 4 speed. With A/T, can only be started in Park or Neutral.
You sure it's a 400? Not available in F100/350's until 1977, has 8 valve cover bolts per side.
Old 10-19-2012, 06:03 PM
Yea, it has eight bolts per cover. If I could figure out how to post pictures on this Web site, I would show you
Old 10-19-2012, 06:44 PM
I've seen more (351C/351M)/400 engines than most FTE members...combined...will see in a lifetime, so I don't need to see any pics.
Characteristics: 8 valve cover bolts per side, the fuel pump bolts to the engine block w/a 6 & 12 o'clock bolt pattern, there is no timing cover per se, just a flat engine cover plate.
Old 10-19-2012, 08:53 PM
I can't tell, the fan is in the way. I saw a post that said something about a switch under the steering column. But I also saw a round cap in the transmission that has wires running along the frame towards the back but the wires are cut about half way down the frame
Old 10-20-2012, 10:55 AM
Freightrain's Avatar
Freightrain Freightrain is offline
Shiftoholic
Freightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to behold
Sounds like someone did some cut'n and likely will take some searching to find the proper wires again.
I know where the plug is under the dash for automatic trucks are and how the back up lights are wired. Not sure if the switch on a 4spd truck comes back and plugs into that same plug? Likely not? Wonder if there is another "tap" somewhere?
Old 10-20-2012, 11:03 AM
4 speed backup lamp switch threads into shift tower. Switch with New Process 435 located in different place than Warner T18.
3 speed manual backup lamp switch located on steering column under hood next to 1st/reverse selector lever.
A/T: Backup lamps are operated thru the neutral safety switch, located towards the bottom of the steering column under the dash. Same switch 1967/77 F100/350.
Old 10-20-2012, 11:34 AM
The truck is automatic. I just saw that the previous owner must have had a hard time with electrical work, there isn't a reverse wire running to the tail light. Now I definitely have to find the reverse switch so I can run a single wire to the tail lights
Old 10-20-2012, 11:52 AM
You cannot see it as it's not a separate wire, it's part of the taillamp harness.
With A/T, the backup lamps are operated thru the NSS.
C7TZ-7A247-A .. NSS = Neutral Safety Switch (Motorcraft SW-600) / ALL 1967/77 F100/350's.
The NSS is located on the steering column under the dash.
Located on the shift tube, thru a hole in the steering column outer shroud is the spring steel NSS selector lever (DOTZ-7B097-B). Has a knife blade end that fits into the NSS.
The little charmer is notorious for having its knife blade end snap off, or the lever loses tensile strength and falls off the tube. When either occurres, the truck can be started in any gear.
Old 10-21-2012, 05:02 PM
Okay, I saw a video on YouTube that shows the switch under the dashboard and in the steering column. I looked on my truck and there is not a hole to mount the switch nor is there a little **** that is connected to the shifting mechanism. In other words, the steering column is a complete pipe all the way through the firewall with no openings to mount the switch. I saw a switch mounting kit on O' Riely's Web site which i'm assuming replicates the switch that i'm SUPPOSED to have. Can anyone verify that the switch kit will work? Its $60 I think
Old 10-22-2012, 01:43 AM
1967/77 F100/350's use the same steering column mounted NSS: C7TZ-7A247-A (Motorcraft SW-600).
1965/77 F100/350's use the same NSS selector lever: DOTZ-7B097-B (replaced C5TZ-7B097-A).
1978/79 F100/350: The NSS is mounted on the transmission. Since the 400 engine has been swapped in, the transmission and the steering column may have also been swapped.
Look on the left (drivers) side of the trans case where the manual control selector lever (shift rod attaches to it) is located...see if the NSS is located there.
1978/79: C6 uses a different NSS than a C4.
Old 10-22-2012, 12:25 PM
Numberdummy- is the part you're talking round in shape and has about three wires coming out of it? It is connected to the manual selector arm right before it connects to the transmission
Old 10-22-2012, 12:44 PM
That's the NSS. 1978/79 F100/350 w/a C6: D8TZ-7A247-A (Motorcraft SW-1489) / Marked: D8TP-AA
Reverse light issue on a 76 Batman7593 1973 - 1979 F-100 & Larger F-Series Trucks 17 05-19-2014 08:30 PM
No reverse lights/No start in neutral. Nick Greer 1973 - 1979 F-100 & Larger F-Series Trucks 13 08-13-2012 11:57 AM
no back up lights 73 fourxfour 1973 - 1979 F-100 & Larger F-Series Trucks 13 10-13-2011 03:20 AM
Reverse Lights not working atccracing 1987 - 1996 F150 & Larger F-Series Trucks 2 01-12-2011 10:11 PM
'71 F100 reverse lights BrookHalvorson 1967 - 1972 F-100 & Larger F-Series Trucks 11 10-04-2005 02:05 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
