Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 6.2L V8
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8 SPONSORED BY:
  #1 (permalink)
Old 10-19-2012, 09:34 AM
pcerra's Avatar
pcerra pcerra is offline
Garage is empty, add now
pcerra is starting off with a positive reputation.
Block heaters
Hi folks
It used to be with the power stroke 7.3 that the block heaters were installed at the factory in every truck. The option just sold you the cable. Does anyone know if this is the case on the 6.2L? I looked at a couple trucks that had the block heater option. Unfortunately the one I am considering buying does not have it listed on the sticker. Anyone know if they all come with the heater in the softplug and only need a cable?
Thanks
Pat
__________________
BUILT WITHOUT A BAILOUT
2012 F250 4X4 ,6.2L, Crew, Short box
2001 F250 4X4 ,7.3 D, Crew, 8 foot box - gone but not forgotten
2006 Mustang GT ragtop
  #2 (permalink)
Old 10-19-2012, 09:47 AM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2011 Ford F-350
2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all
What's the coldest temps your truck will be sitting in? The 6.2 warms up fast, in single digit temps I've had hot air coming out of the vents after 10-15mins of idling. Plus it doesn't have the gelling issues that come with a diesel in cold weather.
From what I remember, if the truck doesn't have it, it's not there at all, you have to get the cord and the mechanism.
__________________
Matt
2011 F350 - 6.2 CC, LB, 4.30s, Lariat Ultimate pkg, FX4, Amp steps, Lockpick, AC LC6i, JL HD900/5, JL 13TW5, JL C5-570's, Bilstein 7100 stabilizer, Rancho RS9000XL's, Leveled w/ 35" Toyo M/T's and 5 Star tuned
**Sold - 2000 F250 V10, 6.5" Pro Comp, 37" Toyo MT's
  #3 (permalink)
Old 10-19-2012, 10:05 AM
pcerra's Avatar
Thanks for the reply.. Upstate NY..Gets below 0 here quite often. The reason I am asking is because I think it's better to have warm oil when its cold gas or diesel.. I know the PS would not start without being plugged in under 20..
__________________
  #4 (permalink)
Old 10-19-2012, 03:29 PM
2011 Ford F-350
You won't have a starting issue with the 6.2. It'll make a bit of noise for a few seconds when it first starts but that's it. I react the same way at those temps though, gasp for a few seconds, then I'm good...
I don't disagree with you though that it would benefit from warmer oil on mornings like that. Looking on fordparts.com, it'd be about $200 to add the element ($50) and cord ($150) yourself.
__________________
Matt
  #5 (permalink)
Old 10-19-2012, 04:24 PM
kmonty2's Avatar
kmonty2 kmonty2 is offline
2011 Ford F-250
kmonty2 is gaining momentum as a positive member of FTE.kmonty2 is gaining momentum as a positive member of FTE.
kmonty
I know that Ford puts them on for free in 15 cold weather states and is standard, MI is one of them. I got mine and it was on the sticker with $0.00 cost. It is a option in the other states. Here are the states that it comes standard in, the truck must also have been ordered for that state to get it for free:AK, CO, IA, ID, ME, MI, MN, MT,ND, NH, NY, SD, VT, WI, WY.
If you have to order it and pay for it from Ford, it cost $75.
__________________
Kevin
2011 F-250 CC, 6.2 Gas, 3.73, 4x4 w/FX4, Tuxedo Black, Steel Cloth interior,Goodyear Wrangler Duratrac's, Air Aid Intake, Bilstein 5100 shocks, Hellwig adjustable sway bar, 5 Star Tuned, Line X bed liner, X Tang Tri-Fold bed cover.
  #6 (permalink)
Old 10-19-2012, 04:27 PM
2011 Ford F-350
Kevin do you ever use yours?
I forgot they came standard in some states.
__________________
Matt
  #7 (permalink)
Old 10-19-2012, 04:54 PM
Big_Daddy_O's Avatar
Big_Daddy_O Big_Daddy_O is offline
Big_Daddy_O is starting off with a positive reputation.
Yep just like metioned above its free in some states. I ordered mine in upstate ny and I live in pa and it came on it free! Or just think of paying $40,000 for the block heater and the truck is free if that makes you feel any better.
__________________
2011 F250 4X4 6.2L CC SB
  #8 (permalink)
Old 10-19-2012, 04:58 PM
kmonty2's Avatar
2011 Ford F-250
kmonty
I do, but not till I know it's below 32. I have a 20 amp timer in the garage and I set it to come on 2 hours before I leave in the morning. This way it don't waste electricity for no reason. I only use because I did have a engine seize on me one time because it got so cold and the oil was kinda old, wife car and was not changed often enough. That will never happen again. It was a $6000 lesson and you learn right away the importance of good oil.
__________________
Kevin
  #9 (permalink)
Old 10-20-2012, 03:48 AM
Rhino-F250 Rhino-F250 is offline
2012 Ford F-250
Rhino-F250 is starting off with a positive reputation.
Asked dealer yesterday how much to install in illinois about $400
  #10 (permalink)
Old 10-20-2012, 08:00 AM
kmonty2's Avatar
2011 Ford F-250
kmonty
That is if they install it, right? If you order it with the truck is only $75.
__________________
Kevin
  #11 (permalink)
Old 10-20-2012, 09:03 AM
Super08's Avatar
Super08 Super08 is offline
2011 Ford F-350
Super08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to behold
To install one you need to drain the coolant out of the engine. Next knock out a frost plug where you want to install the element in the block, then install the element and the cord. Finally put the coolant back in and you are done.
__________________
2012 Ram 3500 Laramie DRW
gone but not forgotten...2011 F350 CC SB Lariat 6.2 4WD 4.30's
  #12 (permalink)
Old 11-12-2012, 07:41 PM
Flatbed Ed Flatbed Ed is offline
Flatbed Ed is starting off with a positive reputation.
Think I'll throw a blanket over the hood on a real cold day. We get a couple days a year in Houston of cold weather.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
