Choke wont shut all the way - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 10-18-2012, 09:10 PM
Adam F Adam F is offline
Adam F is starting off with a positive reputation.
85 E350 Motorhome with 460. Electric choke. Loosen screws, rotate dial and choke only closes about 3/4 of the way. Rotate the other way and the choke opens up all the way. Even with throttle wide open, I can't even close the choke by hand. I have to stuff a rag over the choke to get it to start. Easy solution would be to simply pull the carb and inspect the linkage, but with the van chassis the carb it a real PITA to get at. Hoping this is something simple and you guys can give me some things to look for.
Old 10-22-2012, 07:29 PM
PStruwing's Avatar
PStruwing PStruwing is offline
PStruwing is gaining momentum as a positive member of FTE.
Adam you have bigger issues if you have to put a rag over the carb. First check the vacuum hoses. I bet you have a leak.
Old 10-23-2012, 02:33 AM
pacific350 pacific350 is offline
pacific350 is starting off with a positive reputation.
Used to be carb engines you could put the throttle all the way to the floor before starting to set the choke to full. This is where thing-a-mabob came from. The thingamabob the choke adjustment screw rides on has a spot that when going to full throttle it drops the choke to full. Of course you might have some newer version without that feature but eh. Worth a try.
Carburetor Choke Adjustment Heesman 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 09-05-2014 04:00 PM
17 degrees no choke 1bbl no adjust carb mousetrap65 Ford Inline Six, 200, 250, 4.9L / 300 6 12-02-2007 08:44 PM
351w manual choke not working? towmater 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 07-27-2007 01:08 PM
holley choke help $Simpleman76 Fuel Injection, Carburetion & Fuel System 10 04-23-2007 12:46 AM
Is my choke working properly? 460 Fuel Injection, Carburetion & Fuel System 3 03-05-2006 02:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
