Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 401, 477, & 534 SD Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 10-18-2012, 07:21 PM
Rodney R Rodney R is offline
Garage is empty, add now
Rodney R is starting off with a positive reputation.
534 overheats?
Takes about 1 mile for the needle to peg out at the H, and another half mile for it to start to blow antifreeze out. Both t-stats were removed today, and both open when put on the stove in water.... Upper radiator hose is stone cold.... We're sorta thinking that a hoist is going to be involved.... any other ideas?
Rodney
  #2 (permalink)
Old 10-18-2012, 11:46 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.
A hoist to pull the water pump? Or has it overheated to the point of damage?
  #3 (permalink)
Old 10-19-2012, 05:31 AM
The hoist would be to pull the heads, if the headgasket on one side is blown, but I have no water in the oil, I don't see bubbles in the radiator, and it starts right up and runs like it should.
Rodney
  #4 (permalink)
Old 10-19-2012, 09:49 AM
Back to the pump--is the water moving?
  #5 (permalink)
Old 10-19-2012, 06:38 PM
Turns out that there was a hose on top of the engine, near the front t-stat, for bleeding air. We thought that since the hose went up hill from the motor, the air would come out, and all would be good...... Turns out we were wrong, that a guy has to put the end of the hose lower than the water level, to let some coolant out, and then it's good..... Go figure. This thing has run real warm since a bigger (!) radiatior was installed, but with the t-stats out it now runs cool. That was beginng to get scary, but we haven't reached the end yet, cause the pump does move water (a lot of water) and it gets all foamy...... But it went about 30 miles round trip today, and all was fine.....
Rodney
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
