56 F-100 - EFI Wiring - Ford Truck Enthusiasts Forums
Old 10-18-2012, 02:51 PM
g612gr g612gr is offline
g612gr is starting off with a positive reputation.
Question 56 F-100 - EFI Wiring
I am putting a 1993 Ford Lightning 351W-EFI in the 56 F100 I'm building. I can't seem to find any really clear instructions on what I need for inputs and outputs to make it run right. I know I don't need all the wiring from this harness, but am just somewhat confused. Going to use a 89 Mustang harness and computer? Can anyone direct me to a good sight for more info. I'm a carburetor guy, so this is all new territory for me. Any help will be much appreciated. Hopefully when done I'll have a cool 56 Lightning.
Old 10-18-2012, 07:17 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle Jeff and Nicolle is offline
Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.
This is a good place.
Fuel Injection Technical Library
You should post this on the 87-96 truck forum. They are a big help to the year of motor. "CONANSKI" is really knowledgeable and always posting advice.
i bought a book on ford EFI Charles Probst??? is the author.
here it is.. Ford Fuel Injection & Electronic Engine Control: How to Understand,Service,and Modify : All EEC-IV Systems on Ford,Lincoln,Mercury Cars and Light Trucks 1988-1993: Charles O Probst: 9780837603018: Amazon.com: Books
B.C. Broncos Fuel Injection More reading!
oldfordfuelinjection is a really good source of info.
Hope this helps a little!
Old 10-18-2012, 07:20 PM
Old 10-22-2012, 05:26 PM
Scot's Avatar
Scot Scot is offline
Scot is starting off with a positive reputation.
I just built a '68 Mustang with 5.0 EFI for my wife.
I had little experience with EFI prior to this conversion. I bought a RJM harness and put it on basically a '96 Explorer 5.0 using a Mustang MAF, computer (A9L or A9P) and distributor.
You lay the harness on top of the engine and attach one ground to a specified intake bolt. Then you just start plugging stuff in. It requires 2 power wires that go to the starter solenoid. Then there are fuel pump and pump shutdown wires.
Honestly the hardest part was making the hole for the harness to go through the firewall.
You will need to run an in tank fuel pump because a frame mounted one will vapor lock on long hot days.
super duty lightning swap lhill1995 1999 to 2016 Super Duty 1 07-22-2015 09:35 PM
351w engine build advice Salter70 Performance & General Engine Building 3 08-24-2014 12:13 AM
Project 4x4 lightning Shmike281 1997 - 2003 F150 4 06-03-2014 05:45 PM
lightning 351efi swap Bobby-Gene Farley 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 01-27-2014 09:41 PM
42-Pin Engine Connector Pinout, '97 and '01 fiftyfordfloored 1997 - 2003 F150 0 04-29-2011 01:10 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
