Hello fellow Washingtonians
Thanks for info on 74
As for the 97, The lines connect between the fuel filter (on the rail between the two tanks) and the two tanks, the rear tank works perfect, however the front I get nothing pumping through to the injectors. I am to the point of dropping the front tank, but was hopping it would be something much easier than that.
Thanks for your help
Willyd88,
I see you're Otis Orchards. I'm in Otis also, over by the old Deans Market. Is your 74 a small block or big block FE? 6 degrees advance timing should be a good place to start (vacuum disconnected and plugged, of coarse). I'm sure the 26 deg. you found on the net is for full vacuum advance (full curve).
If your 97 fuel tanks are OEM/electrically switched on the dash, you should have a solenoid valve that switches tank flow, that functions in sync with the fuel pumps. If you've checked the fuse, and replaced the switch, that's the first part. Solenoid and fuel pump would be next in line to check.
billinunionville
06-28-2019 06:21 AM
