Radio antenna connection - Ford Truck Enthusiasts Forums
Old 10-18-2012, 06:53 AM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
More fun with my highly molested 06 XL. My truck has had high end electronics installed prior, was repossessed & sold at auction in Fla. making it's way to a dealer in NC where I bought it.
The radio had no AM and weak FM reception. I opened the dash up to find the antenna cable with a piece of wire taped to the end of it. OK, I pulled the radio (07 factory base line) to see the other end of the wire taped to the back of the radio.
Oh I see what the problem is, I sez to myself, someone snatched the antenna and pulled the cable out so I go pulling on the stump with needle nose pliers, Uh not budging. I look closer and start internet searching to find myself more confused.
The orange antenna cable appears to be what I have seen for 50 years, with a Motorola male end, (which does not plug into the Ford radio).
I found this online Antenna Adapter Works with select 2002-up vehicles (OEM male to Motorola antenna female) at Crutchfield.com
Will this make my radio work properly?
John
Old 10-18-2012, 07:03 PM
carey965 carey965 is offline
carey965 is starting off with a positive reputation.
My stock radio worked with that same plug
I would spend the money on a new aftermarket. You can get a decent bluetooth deck for a hundred bucks
Old 10-18-2012, 09:29 PM
danorules's Avatar
danorules danorules is offline
danorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputation
I would go to the dealer and buy the antenna base and wire. It runs about $20 and then you know its the right wire because its OEM. The install is fairly easy, you just need to loosen the fender near the door and feed the wire through the firewall
Old 10-19-2012, 06:09 AM
jowilker's Avatar
The cable is on the way from Crutchfield.
John
Old 10-22-2012, 05:45 PM
jowilker's Avatar
The antenna connector came today, got it installed, FM is a lot better but still no AM. Any ideas?
I responded to a Craigslist ad for a 05 radio/cd player for $25.00. If it works with a test fit, I will buy it.
John
JBL Antenna cable Spaznaut Explorer, Sport Trac, Mountaineer & Aviator 3 11-29-2016 08:31 PM
Pioneer AVIC-F90BT and XM Radio Tuner Installation in my 2012 F-250 madsonp Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 9 10-27-2016 10:11 PM
2.5kW inverter, RF equipment, Rack install (Note: Many images to load) TRENT310 1999 to 2016 Super Duty 13 10-26-2014 03:46 AM
Mods Continued: Pioneer Navigation Install bridge 6.7L Power Stroke Diesel 19 10-05-2012 08:44 PM
2007 F250 Radio FordSteve79 1999 to 2016 Super Duty 2 08-31-2012 01:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
